Home » Newcomers » Newcomers » How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers(Need steps to install silently with no user interaction)
How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1853076] Thu, 16 June 2022 14:05 Go to next message
I am application packaging engineer. My job is a lot different than a developer's. A lot of developers don't understand that we have to take these applications and make them reach the user/machines with any user interaction or interruptions. I have searched Google, Edge, Reddit etc over and over and cannot find the instructions. As important and wide-spread this product is, its amazing that even Eclipse does not provide actual silent install instructions. Doe anyone know how to install/deploy this product silently?
Re: How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1853083 is a reply to message #1853076] Fri, 17 June 2022 01:13 Go to previous messageGo to next message
Download a package from here and unpackage it to the location of your choice:
Re: How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1854379 is a reply to message #1853083] Tue, 16 August 2022 14:54 Go to previous messageGo to next message
So, there is no "install" per se
Re: How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1854386 is a reply to message #1854379] Wed, 17 August 2022 02:14 Go to previous messageGo to next message
Exactly. Nothing needs to modify the system registry.
Re: How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1859644 is a reply to message #1853083] Wed, 21 June 2023 04:01 Go to previous messageGo to next message
In the past i did (for creating a vagrant box) -->
curl -v -kLO 'https://www.eclipse.org/downloads/download.php?r=1&file=/technology/epp/downloads/release/'$eclipseMonth'/R/'$eclipseVersion'.tar.gz
This works not anymore, instead of the expected packacke a file ,,download.php'' is downloaded.
any ideas ?
Re: How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1859650 is a reply to message #1859644] Wed, 21 June 2023 08:54 Go to previous messageGo to next message
Shall we expand on this? (Yes, it does not help you with "silent install", but it is a peculiar statement ).
First - why do you indirectly expect developers to understand your strange way to package your application ?
Secondly - as a user I would not want anything on my system "installed silently" AKA without my knowledge what is being installed.
And last - Eclipse is IDE so why you need to install it to support your "silent" process to install what ?
Either you are installing for development (IDE) or "ready to run
" application.
PS You do not need to reply to my off the subject post.
Re: How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1859653 is a reply to message #1859650] Wed, 21 June 2023 09:42 Go to previous messageGo to next message
This URL helps to see the direct file system contents of the download server:
https://download.eclipse.org/justj/?file=technology/epp/downloads/release/2023-06/R
The direct links on each file name will directly load it from the server without using a mirror, which might be slow and would be bad if everyone did that. The link on the download icon uses a mirror, which I think you are effectively trying to bypass by specifying r=1.
A URL like this should work too.
https://download.eclipse.org/technology/epp/downloads/release/2023-06/R/eclipse-committers-2023-06-R-linux-gtk-aarch64.tar.gz
I can't say why what you did before stopped working. That would be something likely only the webmaster can answer...
Re: How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1866402 is a reply to message #1853083] Tue, 28 May 2024 17:08 Go to previous messageGo to next message
What about the message "Failed to find a Main Class?"
Re: How to Silently Install /Deploy Eclipse IDE for Enterprise Java and Web Developers [message #1866405 is a reply to message #1866402] Tue, 28 May 2024 19:11 Go to previous message
Steve Upson wrote on Tue, 28 May 2024 17:08
I would question why you're trying to install a 6 year old release, and whether p: is a local disk.
Previous Topic:How to Import new version of a class from a jar file created in another Maven project
Next Topic:Reports on child data sets
Current Time: Thu Nov 06 22:24:45 EST 2025
Powered by FUDForum. Page generated in 0.11943 seconds
