Home » Eclipse Projects » Sirius » Problem with Custom Widgets at higher display scaling
Problem with Custom Widgets at higher display scaling [message #1853073] Thu, 16 June 2022 13:09 Go to next message
We have implemented several custom widgets for the properties. We ran into a problem where if (on Windows at least) the user sets their display settings to be 125% or 150% scaling, the custom widgets are not given enough room in the properties panel and they overlap each other. (it works fine at 175% scaling)
The attached image 100pScaling is how it looks at 100% scaling, and it is fine.
index.php/fa/42196/0/
The attached image 125pScaling is how it looks at 125% scaling, and you can see that the widgets overlap each other and are not fully displayed.
index.php/fa/42197/0/
Is there a way we can implement something on our end to correct this, or should I submit a bug report?
Louis
[Updated on: Thu, 16 June 2022 13:11] by Moderator
Re: Problem with Custom Widgets at higher display scaling [message #1853158 is a reply to message #1853073] Tue, 21 June 2022 02:12 Go to previous messageGo to next message
We can't seem to reproduce this using the standard widgets.
It's difficult to know if the issue in your custom code without knowing it. The only thing I can think of is: are you using the EEFWidgetFactory to create your widgets?
It inherits from org.eclipse.ui.forms.widgets.FormToolkit which normally ensures all widgets are correctly styled and configured.
Re: Problem with Custom Widgets at higher display scaling [message #1853208 is a reply to message #1853158] Wed, 22 June 2022 23:13 Go to previous messageGo to next message
Thank you for your response.
For most of the widgets, we are using the EEFWidgetFactory gotten from an IEEFFormContainer using the method getWidgetFactory.
However, the tables that are to the left of the buttons are NatTables, which can not be created from the EEFWidgetFactory.
Louis
Re: Problem with Custom Widgets at higher display scaling [message #1853379 is a reply to message #1853208] Wed, 29 June 2022 22:19 Go to previous message
For closure, the problem was simply that I was using a height hint for the composite that contained the table and the buttons. Changing this to a minimum height solved the issue.
Previous Topic:Possibility to choose a custom endpoint in an edge?
Next Topic:Double Click supported in sirius-web?
Current Time: Wed May 21 23:06:42 EDT 2025
Powered by FUDForum. Page generated in 0.03795 seconds
