Home » Eclipse Projects » Sirius » EMF Model Creation Wizard fail(Model creation fails)
EMF Model Creation Wizard fail [message #1852947] Sun, 12 June 2022 08:05 Go to next message
Hi everyone,
I have currently problems with creating a model.
I get the following errer message:
The selected wizard could not be started.
Plug-in "AutoDesigner1.editor" was unable to instantiate class "autoDesigner1.presentation.AutoDesigner1ModelWizard".
Here is the .log file:
!SESSION 2022-06-12 13:50:05.508 -----------------------------------------------
eclipse.buildId=4.23.0.I20220308-0310
java.version=16.0.1
java.vendor=Private Build
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -product org.eclipse.platform.ide
Command-line arguments:  -product org.eclipse.platform.ide -data /home/amir2000/eclipse-wokspace-EED-Test/../AutoDesigner_runtime-New_configuration -dev file:/home/amir2000/eclipse-wokspace-EED-Test/.metadata/.plugins/org.eclipse.pde.core/New_configuration/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.jface 2 0 2022-06-12 13:50:12.707
!MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2022-06-12 13:50:12.707
!MESSAGE A conflict occurred for CTRL+SHIFT+T:
Binding(CTRL+SHIFT+T,
	ParameterizedCommand(Command(org.eclipse.jdt.ui.navigate.open.type,Open Type,
		Open a type in a Java editor,
		Category(org.eclipse.ui.category.navigate,Navigate,null,true),
		org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7a7bd9a8,
		,,true),null),
	org.eclipse.ui.defaultAcceleratorConfiguration,
	org.eclipse.ui.contexts.window,,,system)
	ParameterizedCommand(Command(org.eclipse.lsp4e.symbolinworkspace,Go to Symbol in Workspace,
		Category(org.eclipse.lsp4e.category,Language Servers,null,true),
		org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@72b6fa98,
		,,true),null),
!MESSAGE A conflict occurred for ALT+SHIFT+R:
Binding(ALT+SHIFT+R,
	ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.rename.element,Rename - Refactoring ,
		Rename the selected element,
		Category(org.eclipse.jdt.ui.category.refactoring,Refactor - Java,Java Refactoring Actions,true),
		org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1832b0f6,
		,,true),null),
	ParameterizedCommand(Command(org.eclipse.ui.edit.rename,Rename,
		Rename the selected item,
		Category(org.eclipse.ui.category.file,File,null,true),
		org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@6693818c,
		,,true),null),
!ENTRY org.eclipse.ui 2 2 2022-06-12 13:51:02.210
!MESSAGE Invalid property category path: org.springframework.ide.eclipse.beans.ui.properties.ProjectPropertyPage (bundle: org.springframework.ide.eclipse.xml.namespaces, propertyPage: org.springframework.ide.eclipse.beans.ui.namespaces.projectPropertyPage)
[Updated on: Sun, 12 June 2022 08:07] by Moderator
Re: EMF Model Creation Wizard fail [message #1852975 is a reply to message #1852947] Mon, 13 June 2022 11:18 Go to previous messageGo to next message
Hi Amir,
In order to help you as much as possible, could you describe more precisely how you get the error XXX?
Could you also add the details of this error, which you can find in the "Error Log" view (Window > Show view > ...) ? The stack trace you added doesn't seem to match your problem.
You can also follow the BasicFamily tutorial or install the "Sirius Samples" feature to import the "Basic Family Metamodel Definition". The Plug-in Project "org.eclipse.sirius.sample.basicfamily.editor" contains the "org.eclipse.sirius.sample.basicfamily.presentation.BasicfamilyModelWizard" class which you could use as inspiration for the wizard.
https://wiki.eclipse.org/Sirius/Tutorials/BasicFamily#Installing_the_solutions
Glenn
Re: EMF Model Creation Wizard fail [message #1852980 is a reply to message #1852947] Mon, 13 June 2022 13:47 Go to previous messageGo to next message
Hi Glenn,
thank you for the reply. Do you mean the error log from the new configuration or the one from the main workspace. I will send you both. I can only detect some warnings. Beside Keybinding conflicts there is one which says:
However when i create the model instance nothing new is added. Furthermore before the new configuration is started there is one validation problem which is shown in a popup.
The Basic Family Metamodel works perfectly, but I cannot detect any major difference between the ModelWizard classes.
Re: EMF Model Creation Wizard fail [message #1852989 is a reply to message #1852975] Tue, 14 June 2022 04:00 Go to previous messageGo to next message
I replied above
[Updated on: Tue, 14 June 2022 04:00] by Moderator
Re: EMF Model Creation Wizard fail [message #1852994 is a reply to message #1852975] Tue, 14 June 2022 05:32 Go to previous message
I get a more precise error when I try to use the metamodel in odesign.
I think the problem is the gurobi library which is added through a maven dependency. However I also added the jar in Classpath of the project and also configured the environment variables.
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:443)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:352)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:470)
	at org.eclipse.ui.internal.progress.ProgressManager$RunnableWithStatus.run(ProgressManager.java:1117)
	at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:74)
	at org.eclipse.ui.internal.progress.ProgressManager.lambda$27(ProgressManager.java:996)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:6012)
	at org.eclipse.ui.internal.progress.ProgressManager.runInUI(ProgressManager.java:996)
	at org.eclipse.sirius.editor.properties.sections.description.representationdescription.AddFromRegistryButtonListener.widgetSelected(AddFromRegistryButtonListener.java:77)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5895)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1520)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:5126)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4581)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:567)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1440)
Caused by: java.lang.NoClassDefFoundError: gurobi/GRBVar
	at autoDesigner1.impl.AutoDesigner1PackageImpl.initializePackageContents(AutoDesigner1PackageImpl.java:1425)
	at autoDesigner1.impl.AutoDesigner1PackageImpl.init(AutoDesigner1PackageImpl.java:202)
	at autoDesigner1.AutoDesigner1Package.<clinit>(AutoDesigner1Package.java:58)
	at java.base/jdk.internal.misc.Unsafe.ensureClassInitialized0(Native Method)
	at java.base/jdk.internal.misc.Unsafe.ensureClassInitialized(Unsafe.java:1155)
	at java.base/jdk.internal.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(UnsafeFieldAccessorFactory.java:42)
	at java.base/jdk.internal.reflect.ReflectionFactory.newFieldAccessor(ReflectionFactory.java:186)
	at java.base/java.lang.reflect.Field.acquireFieldAccessor(Field.java:1126)
	at java.base/java.lang.reflect.Field.getFieldAccessor(Field.java:1107)
	at java.base/java.lang.reflect.Field.get(Field.java:419)
	at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:304)
	at org.eclipse.sirius.editor.properties.sections.description.representationdescription.DescriptionMetamodelsUpdater.getEPackagesFromNsURI(DescriptionMetamodelsUpdater.java:282)
	at org.eclipse.sirius.editor.properties.sections.description.representationdescription.AddFromRegistryButtonListener$1.run(AddFromRegistryButtonListener.java:83)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:434)
	... 38 more
Caused by: java.lang.ClassNotFoundException: gurobi.GRBVar cannot be found by AutoDesigner1_0.1.0.qualifier
	at org.eclipse.osgi.internal.loader.BundleLoader.generateException(BundleLoader.java:529)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:524)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:416)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:168)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:519)
	... 52 more
[Updated on: Tue, 14 June 2022 06:39] by Moderator
Previous Topic:Specify path for plugin.properties file
Next Topic:How to create an eclipse plugin that registers my metamodel in the current eclipse instance
Current Time: Fri Nov 14 06:15:39 EST 2025
Powered by FUDForum. Page generated in 0.06131 seconds
