Home » Eclipse Projects » Eclipse Scout » AbstractPageField for creating sub-forms
AbstractPageField for creating sub-forms [message #1852406] Sat, 14 May 2022 14:05 Go to next message
J D is currently offline J DFriend
Member
Hi there,
I have a user requirement that demands the creation of a sub-form (a form embedded in another form). On the database level, the link between the two forms is the employee ID.
I've tried to put the sub-form in a GroupBox with an AbstractPageField. I have used the AbstractPageField before elsewhere to display master tables and their detail forms. I figured that I could use it for this particular use case also by hiding the table and displaying only the form. But I have thus far being unsuccessful.
This is what I did:
This code is part of a group box on my EmployeeForm.java
       * the embedded Exit form
      @Order(500)
      public class EmployeeExitPage extends AbstractPageField<ExitNodePage> {
        protected void execInitField() {
          setPage(new ExitNodePage());
          ((ExitForm) getPage().getDetailForm()).getExitFormBox().initializeExitForm();
This is the ExitNodePage.java class
public class ExitNodePage extends AbstractPageWithNodes {
   * No table is used on this page
  // @Override
  // protected void execInitPage() {
  // setTableVisible(false);
  // @Override
  // protected boolean getConfiguredTableVisible() {
  // return false;
  protected Class<? extends IForm> getConfiguredDetailForm() {
    return ExitForm.class;
As is, the best I can get is an empty table with the ExitForm below it. If I try to setTableVisible(false) OR return false from getConfiguredTableVisible() in ExitNodePage.java, the Employee form does not display at al.
Is there anyway I can get around this problem? Or is there any other way this can be achieved?
JD
[Updated on: Sat, 14 May 2022 14:35]
Report message to a moderator
Re: AbstractPageField for creating sub-forms [message #1852430 is a reply to message #1852406] Mon, 16 May 2022 11:13 Go to previous messageGo to next message
Luka Cavic is currently offline Luka CavicFriend
Member
Hi, you need field of type: AbstractWrappedFormField<IForm>.
And set form to it using: setInnerForm(YourFormInstance)
See: https://scout.bsi-software.com/widgets/?dl=widget-wrappedformfield
Re: AbstractPageField for creating sub-forms [message #1852466 is a reply to message #1852430] Tue, 17 May 2022 11:17 Go to previous message
Member
It worked! Thank you very much for your advice, Luka.
JD
Previous Topic:How to add Country Flag to phone number field
Next Topic:Resize the splitter padding & Intelij plugin not working correctly
Current Time: Thu Apr 18 20:47:52 GMT 2024
Powered by FUDForum. Page generated in 0.01747 seconds
