Home » Eclipse Projects » EGit / JGit » Adding JGIT to AEM results in dependency resolving issue
Adding JGIT to AEM results in dependency resolving issue [message #1852387] Fri, 13 May 2022 08:10 Go to next message
Does JGIT use the following artifacts?
  1. sun.net.www.protocol.http -- Cannot be resolved and overwritten by Boot Delegation
  2. sun.security.jgss -- Cannot be resolved and overwritten by Boot Delegation
Re: Adding JGIT to AEM results in dependency resolving issue [message #1852399 is a reply to message #1852387] Fri, 13 May 2022 14:29 Go to previous messageGo to next message
No, JGit does not directly use any JVM-internal packages.
Re: Adding JGIT to AEM results in dependency resolving issue [message #1852419 is a reply to message #1852399] Sun, 15 May 2022 17:48 Go to previous message
https://git.eclipse.org/r/plugins/gitiles/jgit/jgit/+/refs/heads/master/org.eclipse.jgit/src/org/eclipse/jgit/util/GSSManagerFactory.java
may try to load
- sun.net.www.protocol.http.HttpCallerInfo
- sun.security.jgss.HttpCaller
- sun.security.jgss.GSSCaller
- sun.security.jgss.GSSManagerImpl
using reflection to detect which GSSManager implementation should be used
Previous Topic:Update AmazonS3 to authenticate with AWS Signature Version 4
Next Topic:Search all versions of a file with jgit log takes long
Current Time: Sat Jun 21 00:34:40 EDT 2025
Powered by FUDForum. Page generated in 0.04541 seconds
