Home » Modeling » TMF (Xtext) » Get already build xtext resource in languageServer (Get already build xtext resource in languageServer )
Get already build xtext resource in languageServer [message #1851872] Wed, 20 April 2022 17:02 Go to next message
Nagaraj Kandoor is currently offline Nagaraj KandoorFriend
Member
For my project I am introducing new method in language server context. I need to get allready build xtext resource set so that i need not to load resource again.
When the first build happen request method 'initialize' i see projectManager ResourceSet is populated. I just want to reuse xtext resource so i injected ProjectManager in my class but projectManager.getResourceSet() always return null.
@Inject
ProjectManager projectManager;
@JsonRequest(value = "UpdateModel")
public CompletableFuture<?> request(InitializeParams parameter) {
ResourceSet myResource =projectManager.getResourceSet(); // returns  resourceSet null
Looking forward to here from you.
Re: Get already build xtext resource in languageServer [message #1851874 is a reply to message #1851872] Wed, 20 April 2022 17:21 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
I am not sure if this is the correct way of doing what you want to achieve
Is there a reason you don't call requestmanager runread or runwrite methods as other services do
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Get already build xtext resource in languageServer [message #1851892 is a reply to message #1851874] Thu, 21 April 2022 09:26 Go to previous messageGo to next message
Member
@ Christian Dietrich
Thank you for your quick reply.
To Answer your questions I just implemented ILanguageServerExtension and made changes according to that. I was able to achieve new method functionality(Update Model). I just want to optimize this further(if xtext resource already build just use it, instead of loading again).
tried : Once I have IlanguageServerAceess i tried to create ResourceSet based on URI ilanguageServerAceess.newLiveScopeResourceSet(uri); // Resource set got created but no resource added.
I have gone through runRead method If my understanding is correct runRead method work for particular resource and its adding request to queue(ExecutorService).
What I am trying to achieve is get all resource and update model and save.
Re: Get already build xtext resource in languageServer [message #1851894 is a reply to message #1851892] Thu, 21 April 2022 09:42 Go to previous messageGo to next message
If the project manager never does a build resourceset won't be there
Re: Get already build xtext resource in languageServer [message #1851896 is a reply to message #1851894] Thu, 21 April 2022 09:54 Go to previous message
Member
Thank you for your reply.
Previous Topic:LSP4J : Language Server method call never ends
Next Topic:[1...*] cardinality in xtext
Current Time: Fri Mar 31 20:15:49 GMT 2023
Powered by FUDForum. Page generated in 0.02014 seconds
