Home » Modeling » TMF (Xtext) » LSP4J : Language Server method call never ends
LSP4J : Language Server method call never ends [message #1851859] Wed, 20 April 2022 08:20 Go to next message
I have created a Java-based LSP client, but none of the method calls are completed & it waits indefinitely.
Socket socket = new Socket("localhost", 6008);
Launcher<LanguageServer> createClientLauncher = LSPLauncher.createClientLauncher (languageClient,
                socket.getInputStream(), socket.getOutputStream());
LanguageServer server = createClientLauncher.getRemoteProxy();
createClientLauncher.startListening();
InitializeResult result = server.initialize(new InitializeParams()).get();
System.out.println("end");
initialize method never returns. The Language Server is working fine when tested with the VSCode instance.
Seems like requests are not reaching the server as nothing is printed in trace logs of the server.
Server Code -
Function<MessageConsumer, MessageConsumer> wrapper = consumer -> {
			MessageConsumer result = consumer;
			return result;
		Launcher<LanguageClient> launcher = createSocketLauncher(languageServer, LanguageClient.class, new InetSocketAddress("localhost", 6008), Executors.newCachedThreadPool(), wrapper);
		languageServer.connect(launcher.getRemoteProxy());
		Future<?> future = launcher.startListening();
		while (!future.isDone()) {
			Thread.sleep(10_000l);
What could be the issue here?
Re: LSP4J : Language Server method call never ends [message #1851868 is a reply to message #1851859] Wed, 20 April 2022 12:15 Go to previous message
cannot reproduce this with the snippet you share.
do you mean that the main method does not stop?
you dont call System.exit(0); at end
Did you debug if the startListening in the client blocks
Are you sure you create the client socket connection correct ?
Does anything at the server arrive using debugger
I also wonder if you should use AsynchronousSocketChannel
As others do
Maybe you can also check how lsp4e uses
https://github.com/eclipse/lsp4e/blob/607e86e697e49e4f1cb1969ecdf9009cbfa47df4/org.eclipse.lsp4e/src/org/eclipse/lsp4e/server/ProcessOverSocketStreamConnectionProvider.java
you can also check out
https://github.com/TypeFox/lsp4j-chat-app/blob/master/src/main/java/io/typefox/lsp4j/chat/shared/SocketLauncher.java
https://github.com/TypeFox/lsp4j-chat-app/blob/master/src/main/java/io/typefox/lsp4j/chat/client/ChatClientLauncher.java
[Updated on: Wed, 20 April 2022 14:52] by Moderator
Previous Topic:Packages does not exist from Xtext Maven Example
Next Topic:Get already build xtext resource in languageServer
Current Time: Wed Apr 30 11:54:44 EDT 2025
Powered by FUDForum. Page generated in 0.05765 seconds
