Creating .Net Core projects [message #1851850] |
Wed, 20 April 2022 01:04 |
Sam Hobbs Messages: 20 Registered: July 2010 |
This question might require familiarity with .Net Core to answer it.
I have been doing the following to create a .Net Core project and push to a new GitHub repository.
- Create empty repository in GitHub
- Create a project using dotnet command in a new directory
- Open project from file system
- Share project (create local repository)
- Modify files
- Commit and push
For those unfamiliar with .Net, that works, but getting the local and remote repositories connected seems a bit cumbersome. I can do it but then I tried doing the following.
- Import the repository into Eclipse
- Create project using dotnet command in the project's directory
- Refresh Eclipse of course
- Modify files
- Commit and push
That is easier for me. Is there a potential problem (relevant to Eclipse) I do not realize?
One thing I am not sure of is whether to import as New Project wizard or as general project. The default is general project and I assume that since it is an empty repository, New Project wizard would do nothing I need done.
For what it is worth, I am currently using How to deploy ASP.NET Blazor WebAssembly to GitHub Pages and using Eclipse for the IDE instead of Visual Studio or Visual Studio Code.
[Updated on: Wed, 20 April 2022 03:08] Report message to a moderator
FUDForum. Page generated in 0.04007 seconds
