Home » Newcomers » Newcomers » Stuck trying to set up Eclipse Che as an in-browser IDE
Stuck trying to set up Eclipse Che as an in-browser IDE [message #1851751] Thu, 14 April 2022 20:44 Go to next message
Ryan Westlund is currently offline Ryan WestlundFriend
I'm a noob at both Kubernetes and Eclipse Che who's trying to run Eclipse Che on a k3s cluster. I'm not sure if what I'm trying to do is supported or not; my ultimate goal is to get Eclipse Che integrated into a webpage where you can use it to write code inside a pod being used as a development environment (this pod is not managed by Eclipse).
The cluster is all on localhost for development, so to deploy Che I am running `chectl server:deploy --platform=k8s --domain=172.18.0.3.nip.io --skip-oidc-provider-check`. The output shows that everything succeeds except starting the "Eclipse Che server pod", on which it says "Failed to start a pod, reason: Error, exit code: 137"), and I'm at a loss for how to get any other information about the cause. (The error log file contains nothing else).
Looking at the pods in `kubectl get pod -n eclipse-che` output, I see che-operator, postgres, devfile-registry, plugin-registry, che-dashboard, and just 'che' are running, while che-gateway is in CrashLoopBackOff.
When I check `kubectl get services -n eclipse-che`, I see the services che-host, che-dashboard, che-gateway, postgres, devfile-registry, and plugin-registry. They have ports assigned, but trying to ncat to the k3s node (which is running at 172.18.0.3) on those ports always says connection refused. I notice these services are of type ClusterIP whereas the ones I had set up before involving Che in the project were of type NodePort and had pairs of ports (like 22:31294), whereas these ClusterIP services have only individual ports.
I also tried to reach some of the ClusterIP addressses; the result is always a timeout when connecting, regardless of whether I use the correct port or not.
There's a API running which I only found out about from trying to run `chectl server:delete` and it told me about the server at https://0.0.0.0:33985. I tried hitting this API; it returns a JSON object saying Unauthorized.
When searching for similar issues I encountered some screenshots of people who'd made it to a dashboard and were getting an Unauthorized error at it, so I think there's supposed to be a dashboard I can access that uses this API, but I don't know where that dashboard is at or if it won't be accessible because che-gateway failed.
So I have multiple things that seem like they're not working as intended (gateway pod failing to start, no public endpoint to reach the dashboard), but don't know how to proceed on any of them. I have no idea if these issues could be caused by running it on localhost or by skipping the OIDC provider check (and if so how I would install an OIDC provider.) I have checked all the documentation and Github threads I can find.
Re: Stuck trying to set up Eclipse Che as an in-browser IDE [message #1851754 is a reply to message #1851751] Fri, 15 April 2022 04:07 Go to previous messageGo to next message
Update: I have tried running v7.41.2 instead; this appears to be able to create all the pods successfully (and without passing --skip-oidc-provider-check); in particular i notice it provisions a keycloak pod automatically. Upon finishing it tells me an address to go to the dashboard (che-eclipse-che.172.18.0.3.nip.io), but that server always returns a plain "404 page not found" message, over either http or https. I have checked the dashboard pod log - nothing suspicious, only some output saying the dashboard started and showing what routes should be available (all return 404 page not found).
Re: Stuck trying to set up Eclipse Che as an in-browser IDE [message #1851760 is a reply to message #1851754] Fri, 15 April 2022 05:16 Go to previous message
It's certainly not easy finding where you should ask questions about Che, but it's unlikely people will answer here. Looking here I see only their mailing list:
https://projects.eclipse.org/projects/ecd.che/contact
They have a whole whack of repos:
https://projects.eclipse.org/projects/ecd.che/developer
Maybe one issue is that they don't really document any place to ask users questions:
https://github.com/eclipse/che/issues
Ed Merks
Previous Topic:My Console Output Vanishes -- Why???
Next Topic:Prolog plugin and XSB Prolog interpreter
Current Time: Mon Dec 05 18:26:09 GMT 2022
Powered by FUDForum. Page generated in 0.03189 seconds
