Home » Modeling » TMF (Xtext) » Packages does not exist from Xtext Maven Example
Packages does not exist from Xtext Maven Example [message #1851750] Thu, 14 April 2022 18:47 Go to next message
Clark Gable is currently offline Clark GableFriend
I am currently new to Xtext and LSP and tried to create a .jar from the sample project to create a language server to use in a VSCode extension. Unfortunately, when I run Maven install on the parent to create the .jar of the language server, the following errors appear:
/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[15,29] package org.junit.jupiter.api does not exist
[ERROR]...org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[16,29] package org.junit.jupiter.api does not exist
[ERROR].../org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[17,39] package org.junit.jupiter.api.extension does not exist
[ERROR].../org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[20,2] cannot find symbol
[ERROR]   symbol: class ExtendWith
[ERROR].../org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[21,2] cannot find symbol
[ERROR]   symbol: class InjectWith
[ERROR]...org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[25,11] cannot find symbol
[ERROR]   symbol:   class ParseHelper
[ERROR]   location: class org.xtext.example.mydsl.tests.MyDslParsingTest
[ERROR].../org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[20,13] cannot find symbol
[ERROR]   symbol: class InjectionExtension
[ERROR]...org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[21,13] cannot find symbol
[ERROR]   symbol: class MyDslInjectorProvider
[ERROR].../org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[27,4] cannot find symbol
[ERROR]   symbol:   class Test
[ERROR].../org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[34,7] cannot find symbol
[ERROR]   symbol:   variable Assertions
[ERROR].../org.xtext.example.mydsl.parent/org.xtext.example.mydsl.tests/xtend-gen/org/xtext/example/mydsl/tests/MyDslParsingTest.java:[41,7] cannot find symbol
The build error is only in the tests:
[INFO] Reactor Summary for org.xtext.example.mydsl.parent 1.0.0-SNAPSHOT:
[INFO]
[INFO] org.xtext.example.mydsl.parent ..................... SUCCESS [  0.273 s]
[INFO] org.xtext.example.mydsl ............................ SUCCESS [ 11.450 s]
[INFO] org.xtext.example.mydsl.ide ........................ SUCCESS [  3.172 s]
[INFO] org.xtext.example.mydsl.tests ...................... FAILURE [  0.302 s]
Here is what I did:
1. Create new Xtext Project (Java 11, Maven, Fat Jar)
2. Generate Xtext artifacts from MyDsl.xtext
3. mydsl.parent -> Run As "Maven install"
Eclipse: Version: 2022-03 (4.23.0)
Xtext: Version: 2.26.0.v20220228-0901
Java: 11.0.14
I'm not that familiar with the tools, so can somebody help me with this? Thank you very much in advance!
Re: Packages does not exist from Xtext Maven Example [message #1851775 is a reply to message #1851750] Fri, 15 April 2022 09:33 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
did you select or deselect eclipse in the wizard?
if you did not deselct how does your mydsl.target file look like?
does it work if you run maven with a dedicated repo? (-Dmaven.repo.local=somepath)
if not can you provide your project or reproducer as github repo orr similar
Twitter : @chrdietrich
[Updated on: Fri, 15 April 2022 09:39]
Report message to a moderator
Re: Packages does not exist from Xtext Maven Example [message #1851778 is a reply to message #1851775] Fri, 15 April 2022 10:41 Go to previous messageGo to next message
Yes, I deselected eclipse in the wizard.
You can find the project here: https://github.com/dbfuh/Xtext-languageserver
Re: Packages does not exist from Xtext Maven Example [message #1851781 is a reply to message #1851778] Fri, 15 April 2022 11:23 Go to previous messageGo to next message
this projects builds perfectly fine for me with
org.xtext.example.mydsl.parent]$ mvn clean install -Dmaven.repo.local=.m2
[INFO] ------------------------------------------------------------------------
[INFO]
[INFO] org.xtext.example.mydsl.parent ..................... SUCCESS [  7.819 s]
[INFO] org.xtext.example.mydsl ............................ SUCCESS [01:09 min]
[INFO] org.xtext.example.mydsl.ide ........................ SUCCESS [ 11.468 s]
[INFO] org.xtext.example.mydsl.tests ...................... SUCCESS [  7.472 s]
[INFO] BUILD SUCCESS
[INFO] Total time:  01:37 min
[INFO] Finished at: 2022-04-15T13:21:51+02:00
so i assume you have some broken files floating around in your local maven repo.
Re: Packages does not exist from Xtext Maven Example [message #1851793 is a reply to message #1851781] Fri, 15 April 2022 18:44 Go to previous messageGo to next message
Thank you for your response!
Ok, so with
it works but it with "Maven Install" from eclipse I get the error even when I delete the .m2 repository before.
Re: Packages does not exist from Xtext Maven Example [message #1851797 is a reply to message #1851793] Sat, 16 April 2022 05:17 Go to previous message
the questions would be. which maven repo does "from" eclipse use.
you can specify the -Dmaven.repo.local there too in the vm args line.
i assume the one in your user home.
and how does the jar containg the missing classes
$HOME /.m2/repository/org/junit/jupiter/junit-jupiter-api/5.8.1/junit-jupiter-api-5.8.1.jar look like.
is it a real jar? with proper content?
the next question would be: which java version does it use and which maven version
[Updated on: Sat, 16 April 2022 05:41]
Previous Topic:Allow cross-references to "built-in" types
Next Topic:LSP4J : Language Server method call never ends
Current Time: Fri Feb 23 04:54:16 GMT 2024
Powered by FUDForum. Page generated in 0.02261 seconds
