Update language server UI in non UI thread [message #1851297] |
Fri, 01 April 2022 16:58 |
Nagaraj Kandoor Messages: 56 Registered: May 2020 |
Member |
Eclipse has Display.getDefault().asyncExec method for updating UI from non ui thread.
How do we update language server Ui ?
My first request from VS code editor(Cnt + space) is getting failed, subsequent request is getting successful.
Any suggestion how to I investigate this further ?
Looking forward for your reply.
[Error - 6:05:44 PM] Request textDocument/completion failed.
Message: Internal error.
Code: -32603
java.util.concurrent.CompletionException: java.lang.NullPointerException
at java.util.concurrent.CompletableFuture.encodeThrowable(Unknown Source)
at java.util.concurrent.CompletableFuture.completeThrowable(Unknown Source)
at java.util.concurrent.CompletableFuture.uniAccept(Unknown Source)
at java.util.concurrent.CompletableFuture$UniAccept.tryFire(Unknown Source)
at java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.util.concurrent.CompletableFuture.completeExceptionally(Unknown Source)
at org.eclipse.xtext.ide.server.concurrent.AbstractRequest.logAndCompleteExceptionally(AbstractRequest.java:73)
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:69)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at com.text.dsl.ui.contentassist.BaseTemplateProposal.createSnippet(BaseTemplateProposal.xtend:48)
at com.text.dsl.ui.contentassist.BaseTemplateProposal.addInstanceProposal(BaseTemplateProposal.xtend:30)
at com.text.dsl.ui.contentassist.TextDslTemplateProposalProviderUtil.proposeInstanceClasses(TextDslTemplateProposalProviderUtil.xtend:734)
at com.text.dsl.ui.contentassist.TextDslTemplateProposalProviderUtil.addInstanceOrFeatureTemplate(TextDslTemplateProposalProviderUtil.xtend:672)
at com.text.dsl.ide.contentassist.TextDslIdeContentTemplateProposalProvider.createTemplates(TextDslIdeContentTemplateProposalProvider.xtend:56)
at com.text.dsl.ide.contentassist.TextDslIdeContentProposalProvider._createProposals(TextDslIdeContentProposalProvider.xtend:41)
at com.text.dsl.ide.contentassist.TextDslIdeContentProposalProvider.createProposals(TextDslIdeContentProposalProvider.xtend:31)
at org.eclipse.xtext.ide.editor.contentassist.IdeContentProposalProvider.createProposals(IdeContentProposalProvider.java:71)
at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createProposals(ContentAssistService.java:104)
at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createCompletionList(ContentAssistService.java:77)
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$completion$22(LanguageServerImpl.java:551)
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:438)
at org.eclipse.xtext.ide.server.LanguageServerImpl.completion(LanguageServerImpl.java:550)
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$completion$21(LanguageServerImpl.java:536)
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:66)
[Updated on: Fri, 01 April 2022 19:10] Report message to a moderator
FUDForum. Page generated in 0.03322 seconds
