Home » Modeling » TMF (Xtext) » Register Xtext Resource Factory in Xtend
Register Xtext Resource Factory in Xtend [message #1851084] Sun, 27 March 2022 11:16 Go to next message
I am trying to use n Xtext file (the instance of my dsl), as input to Xtend to generate code. I am getting the following error:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.xml.sax.SAXParseExceptionpublicId: file:/Users/User/runtime-Transf/tranform/A2B.mydsl; systemId: file:/Users/User/runtime-Transf/tranform/A2B.mydsl; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
	at xtendpaxckage.transform.Setup(transform.java:195)
From what I read, this usually occurs when there are issues with registering Resource Factories.
I know how to do that for Ecore or Xmi resource factories , but not for Xtext.
In this thread https://bugs.eclipse.org/bugs/show_bug.cgi?id=531399 I see it says I have to register by using doSetup and so I did.
In Xtend I have this now:
def Setup(){
resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION, new EcoreResourceFactoryImpl());
MyDslStandaloneSetup.doSetup
resource = resourceSet.getResource( URI.createFileURI(new File("A2B.mydsl").getAbsolutePath()), true);
However, when I do this I get the following error:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/xtext/ISetup
	at java.base/java.lang.ClassLoader.defineClass1(Native Method)
	at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1017)
	at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:174)
	at java.base/jdk.internal.loader.BuiltinClassLoader.defineClass(BuiltinClassLoader.java:800)
	at java.base/jdk.internal.loader.BuiltinClassLoader.findClassOnClassPathOrNull(BuiltinClassLoader.java:698)
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(BuiltinClassLoader.java:621)
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:579)
	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
Am I doing something wrong in this last step, or is this not the correct way at all to register the resource correctly?
Thank you!
Re: Register Xtext Resource Factory in Xtend [message #1851086 is a reply to message #1851084] Sun, 27 March 2022 11:27 Go to previous messageGo to next message
This looks like an incomplete classpath
Usually you can also call new mydslstandalonesetup().cresteinjectoranddoemfregistration()
And then call getInstance(Resourceset.class) to get the resourceset to load
Re: Register Xtext Resource Factory in Xtend [message #1851087 is a reply to message #1851086] Sun, 27 March 2022 12:42 Go to previous messageGo to next message
Hi Christian,
Do you mean something like this?
injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration;
injector.getInstance(resourceSet.class)
resourceSet.getPackageRegistry().put(MyDslPackage.eNS_URI, MyDslPackage.eINSTANCE);
Even when I run this one, I still get:
Re: Register Xtext Resource Factory in Xtend [message #1851089 is a reply to message #1851087] Sun, 27 March 2022 13:53 Go to previous message
No Xtend code would be
val injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration;
val resourceSet = injector.getInstance(ResourceSet)
No messing with registry
[Updated on: Sun, 27 March 2022 13:54] by Moderator
Previous Topic:General Xtext question
Next Topic:Use Xtext Editor for a model field
Current Time: Thu Jun 12 12:36:08 EDT 2025
Powered by FUDForum. Page generated in 0.05443 seconds
