Home » Modeling » TMF (Xtext) » Xtext & Build Loops
Xtext & Build Loops [message #1850837] Fri, 18 March 2022 08:29 Go to next message
Christian Dietrich is currently offline Christian DietrichFriend
As you might know Xtext requests rebuilds if there are files generated and or changes reported by jdt.
some time ago platform limited the number of the build cycles which may lead to the problem that not everything is built
together with platform we are working on a solution that targets all different needs
https://bugs.eclipse.org/bugs/show_bug.cgi?id=579082
the patch in platform is available in the current 4.24 I-builds
and the patch in Xtext (XtextBuilder) is available in the current Xtext Nightly
(https://download.eclipse.org/modeling/tmf/xtext/updates/nightly)
it would be nice if you can give it a try and give early feedback
Twitter : @chrdietrich
Re: Xtext & Build Loops [message #1850846 is a reply to message #1850837] Fri, 18 March 2022 12:16 Go to previous messageGo to next message
Great news. This is very encouraging.
My attempts to investigate in the past were hampered by no obviously good .options setting to enable the recursions to be logged. No advice was forthcoming.
Is there now a .options that can be set to log each build activation?
It is unlikely that the Xtext builder is the only builder with sub-optimal strategy. A .options that enables other builders to be diagnosed would be good.
Ed Willink
Re: Xtext & Build Loops [message #1850848 is a reply to message #1850846] Fri, 18 March 2022 13:35 Go to previous messageGo to next message
no but you can open the xtext build console
am not sure what the normal platform build loggers are logging
[Updated on: Fri, 18 March 2022 14:07]
Report message to a moderator
Re: Xtext & Build Loops [message #1850855 is a reply to message #1850848] Fri, 18 March 2022 16:08 Go to previous messageGo to next message
Thanks not aware of the Xtext Console.
It certainly gives me a key to some total time burners such as:
[Worker-41: Build Project] indexing platform:/resource/org.eclipse.uml2.uml/model/UML30.ecore
Why is a *.ecore in a project without an Xtext nature indexed?
Why after cleaning org.eclipse.ocl.examples.build is org.eclipse.uml2.uml re-indexed? Ok it's transitively referenced but it's not dirty and not clean all.
Ed Willink
Re: Xtext & Build Loops [message #1850858 is a reply to message #1850855] Fri, 18 March 2022 16:38 Go to previous messageGo to next message
i believe the ecore thing was discussed in a bugzilla i cannot find between sebastian and you before.
and no we did not change any logic in xtext. we just call tell the platform to rebuild the current project
and not all projects as we did before.
what does the log tell when you see the indexing message.
which project is it building?
[Updated on: Fri, 18 March 2022 17:00]
Re: Xtext & Build Loops [message #1850861 is a reply to message #1850858] Fri, 18 March 2022 19:23 Go to previous messageGo to next message
It's just the one cleaned project that's building. But all the referenced projects are indexed regardless of Xtext nature. So all the big UML files.
Ed
Re: Xtext & Build Loops [message #1850885 is a reply to message #1850861] Mon, 21 March 2022 08:38 Go to previous messageGo to next message
Still using 2022-03, I now have the Xtext Build Console active and can see that most of the time, everything is reasonable, a build is requested and nothing needs doing.
But sometimes there is action and I can now go back and investigate after the event, but ...
It would be really helpful if as well as the Built elapsed time at the end there was a Building absolute start time at the front, and possibly a diagnosis of the build trigger (at least full/incremental and maybe the dirty files list).
(The triggers could help identify why a real build seems to have a no-action build just before and just after.)
Ed Willink
Re: Xtext & Build Loops [message #1850952 is a reply to message #1850885] Wed, 23 March 2022 09:58 Go to previous messageGo to next message
patch was updated to support https://github.com/eclipse/xtext-eclipse/issues/1820
Re: Xtext & Build Loops [message #1851151 is a reply to message #1850952] Tue, 29 March 2022 07:28 Go to previous message
An updated variant of the patches in Platform and Xtext is available in the latest
4.24 I-Builds and in the Xtext nightly
Previous Topic:Xtext maven plugin language order
Next Topic:Reference Epackage
Current Time: Thu Feb 22 14:56:44 GMT 2024
Powered by FUDForum. Page generated in 0.02501 seconds
