Home » Modeling » TMF (Xtext) » How to avoid ambiguity
How to avoid ambiguity [message #1850696] Mon, 14 March 2022 18:11 Go to next message
Konrad Jünemann is currently offline Konrad JünemannFriend
Member
I have a grammar that should be able to model Annotations.
The simplified grammar looks like this:
Item:
   (annotations+=Annotation)?
   name=ID
Annotation:
  {Annotation}
  AnnotationName ( '(' ')' )?
fragment AnnotationName * hidden () :
   '@' name=ID
It should work as follows:
@MyAnn MyItem {}
The problem is that I would like to allow annotations with an empty name (just syntactically, as I later want to propose all available annotation names when the user just enters an '@' character). However, just making the name optional by modifying it to
   '@' (name=ID)?
does not work, as now the expression
@Name {}
would introduce ambiguity (is "Name" the name of the annotation or the item?).
I tried to "force" whitespaces after the Annotation name, but this did not work either - I still get "no viable alternative at input" error, although the dsl does parse successfully.
   '@' (name=ID | WS)
After all,
@ Name {}
should parse as a single Item with name "Name" that possesses an unnamed annotation.
Any ideas how I would design a grammar like this?
Re: How to avoid ambiguity [message #1850697 is a reply to message #1850696] Mon, 14 March 2022 19:06 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
did you try to use predicate?
'@' ->name=ID?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: How to avoid ambiguity [message #1850698 is a reply to message #1850697] Mon, 14 March 2022 19:44 Go to previous messageGo to next message
I always try to avoid syntactic predicates, since IMHO the need for such a fix is a sign that the grammar is poorly designed and consequently hides surprises for your users.
Perhaps it's time to take a step back. Are blank named annotations really such a good idea? If they really are then you perhaps need a syntax for the blank name. If you allow an annotation name to be an ID or STRING then you could use @'' for the blank name. Or braces or ...
Ed Willink
Re: How to avoid ambiguity [message #1850699 is a reply to message #1850697] Mon, 14 March 2022 19:50 Go to previous messageGo to next message
Member
'@' ->name=ID?
I did, but it apparently did nothing - at least nothing I noticed. I still get the "the decision cannot distinguish between alternative(s)"... error when parsing the grammar. Is there any way I can debug in more detail what goes wrong?
( I tried both the -> and the => predicates, both at the AnnotationName and Item locations)
[Updated on: Mon, 14 March 2022 19:57]
Report message to a moderator
Re: How to avoid ambiguity [message #1850700 is a reply to message #1850698] Mon, 14 March 2022 19:57 Go to previous messageGo to next message
Member
Ed Willink wrote on Mon, 14 March 2022 19:44
I don't actually want to allow blank named annotations - I just want to support them syntactically, not semantically. I wrote a validation that throws errors for blank annotations. The reason I want to allow blank annotations is that I want to propose (during content assist) which annotations are allowed at this specific item - in order to do so I need the (following) item to be parseable.
To be more specific: when the user types a '@' character content assist should already propose all valid annotations. But if the model is not syntactically correct in this state, I cannot do that (as I cannot analyze the following item).
Edit: the rule my grammar should follow is actually quite simple, I just don't know how to implement it, if it is possible at all:
- if there follows an ID directly after the '@' character (without any whitespaces), then this is the name of the annotation, no matter what characters follow.
- if there follows no ID, then the name of the annotation should be blank.
[Updated on: Mon, 14 March 2022 20:08]
Re: How to avoid ambiguity [message #1850702 is a reply to message #1850700] Mon, 14 March 2022 20:11 Go to previous messageGo to next message
can you please provide complete grammar?
Item:
   {Item}(annotations+=Annotation)?
   name=ID?
Annotation:
  {Annotation}
   '@' ->name=ID?
does not complain
[Updated on: Mon, 14 March 2022 20:15]
Re: How to avoid ambiguity [message #1850703 is a reply to message #1850702] Mon, 14 March 2022 20:23 Go to previous messageGo to next message
Member
Thanks, I will. My grammar is in reality a bit more complex. I will start at the grammar you provided and try to get to my actual grammar.
Re: How to avoid ambiguity [message #1850704 is a reply to message #1850703] Mon, 14 March 2022 20:45 Go to previous messageGo to next message
Member
OK, the problem seems to be that the item's block brackets are optional too.
This should work (even without predicate):
Item:
   name=ID
Annotation:
  {Annotation}
   '@' name=ID?
This should not work (with or without predicate):
Item:
   name=ID
Annotation:
  {Annotation}
   '@' ->name=ID?
Is there another trick I could try?
[Updated on: Mon, 14 March 2022 20:45]
Re: How to avoid ambiguity [message #1850705 is a reply to message #1850704] Mon, 14 March 2022 20:50 Go to previous messageGo to next message
->'@' ->name=ID?
am not sure if this gives you the correct result for the ambigous model
Re: How to avoid ambiguity [message #1850706 is a reply to message #1850705] Mon, 14 March 2022 21:05 Go to previous messageGo to next message
Member
Great, thank you. That works for this example. I will now try to incorporate this solution pattern into my real grammar - thanks for your great input!
Re: How to avoid ambiguity [message #1850740 is a reply to message #1850706] Tue, 15 March 2022 18:16 Go to previous messageGo to next message
Member
I tried to extrapolate the proposed solution to my real grammar and was unable to get it to work. Here is a fairly minimal grammar that illustrates the problem:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	enumerations+=Enumeration*;
Enumeration:
   {Enumeration}
   name=ID
  		 encodings+=Encoding ( ',' encodings+=Encoding)*
Encoding:
	Annotations
	name=ID
fragment Annotations * :
   (annotations+=Annotation)*
Annotation:
  {Annotation}
   		'@' name=ID?
Here is a couple of test cases that should all parse correctly:
MyEnumeration {
	Test1,
	@ABC()
	Test2,
	@ABC
	Test3,
	@ABC()
	@DEF
	Test4,
	Test5,
	Test6,
	@DEF
	@ABC()
	Test7,
The grammar posted above throws the error:
error(202): ../org.xtext.example.mydsl/src-gen/org/xtext/example/mydsl/parser/antlr/internal/InternalMyDsl.g:356:3: the decision cannot distinguish between alternative(s) 1,2 for input such as "RULE_ID EOF EOF"
I tried to debug it with ANTLRWorks, with no success - I am probably dooing it wrong, but ANTLRworks shows no problems to me. I then tried to use predicates, following the guide here: https://www.slideshare.net/schwurbel/getting-rid-of-backtracking (written by Jan Köhnlein), but to no avail.
Maybe you guys have another hint what I could try? Or is it simply not possible to create a grammar like this (with justifiable effort)?
Re: How to avoid ambiguity [message #1850741 is a reply to message #1850740] Tue, 15 March 2022 19:32 Go to previous messageGo to next message
i really suggest to generate a debug grammar and get familiar with antlrworks
Re: How to avoid ambiguity [message #1850742 is a reply to message #1850741] Tue, 15 March 2022 19:40 Go to previous messageGo to next message
and maybe start analyzing the real minimal model
Model2:
encodings+=Encoding
Encoding:
name=ID
Annotation:
{Annotation}
'@' name=ID?
btw is this an existing lang?
[Updated on: Tue, 15 March 2022 19:43]
Re: How to avoid ambiguity [message #1850743 is a reply to message #1850742] Tue, 15 March 2022 19:44 Go to previous messageGo to next message
Member
the grammar I provided is the debug grammar...
But OK, I think I will look into ANLRWorks a bit more. I guess the simplest solution is to just introduce a couple of new keywords into my grammar. This should simplify things a lot.
Thanks for your help!
Re: How to avoid ambiguity [message #1850744 is a reply to message #1850743] Tue, 15 March 2022 19:48 Go to previous messageGo to next message
no you can configure
workflow
to have a debug grammar
you can load into antlrworks
maybe this helps you to understand where antlr seen the ambiguity
Re: How to avoid ambiguity [message #1850745 is a reply to message #1850744] Tue, 15 March 2022 19:51 Go to previous messageGo to next message
very naive question:
why fragment and hidden stuff and not a terminal? (+ value converter)
terminal ANNOTATION_NAME :
'@' ID?
[Updated on: Tue, 15 March 2022 19:51]
Re: How to avoid ambiguity [message #1850759 is a reply to message #1850745] Wed, 16 March 2022 08:58 Go to previous message
Member
workflow
Oh, I misunderstood you. Yeah, I already did that - for some reason the debug-grammer did not show a disambiguity while the "real" grammer did.
Thank you so much, that was exactly the right idea. Don't know why I did not think of it, but this solves the problem perfectly. It also simplifies the grammar and I don't have to deal with predicates. Works fine no, even in my real grammar. Thanks!
Regarding my other approach: I don't think it is possible to achieve what I want using the "fragment + hidden()" approach. At least I did not get it to work, even with the simplest grammar. But I will not look into it any longer as the Terminal-approach is much cleaner.
Previous Topic:Language server not responding to client request
Next Topic:Syntax-Error for LessThan-Keyword
Current Time: Tue Mar 21 22:00:13 GMT 2023
Powered by FUDForum. Page generated in 0.02734 seconds
