Validating all diagrams in a session [message #1850369] |
Mon, 28 February 2022 07:26 |
Simon Tulia Messages: 14 Registered: January 2022 |
Hello all,
I would like to programmatically validate all diagrams in a session, respectively. For this, I traverse through the diagrams, but encounter with a problem when I get the editor object. This is basically what I am trying to do:
public boolean validateAllDiagrams(EObject self){
Session session = SessionManager.INSTANCE.getSession(self);
Collection<DRepresentation> representationList = DialectManager.INSTANCE.getAllRepresentations(session);
for(DRepresentation rep: representationList ){
if(rep instanceof DDiagram){
IEditorPart editorPart = DialectUIManager.INSTANCE.openEditor(session, rep, new NullProgressMonitor());
WorkbenchPartDescriptor workbenchPartDescriptor = new WorkbenchPartDescriptor(editorPart.getSite().getId(), editorPart.getClass(), editorPart.getSite().getPage());
ValidateAction va = new ValidateAction(workbenchPartDescriptor);
va.run();
However, during the execution of DialectUIManager.INSTANCE.openEditor function, I am getting the following exception. If the editor has been already opened, the exception does not occur. Actually, I do not need to open the editor, but I could not find any way to get an object related to the editor to call va.run() function [1]. So, I wonder how I can validate all diagrams or access to DialectEditor objects.
!ENTRY org.eclipse.ui 4 4 2022-02-28 10:18:29.505
!MESSAGE Unable to create part
!STACK 1
org.eclipse.ui.PartInitException: Cannot activate read/write transaction in read-only transaction context
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:346)
at sun.reflect.GeneratedMethodAccessor81.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:999)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:964)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:405)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:332)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:1000)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:660)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:737)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:731)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:107)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4735)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:219)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:132)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:658)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:622)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:790)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1263)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3195)
at org.eclipse.ui.internal.WorkbenchPage.lambda$9(WorkbenchPage.java:3100)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:72)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3098)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3068)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3051)
at org.eclipse.sirius.diagram.ui.business.internal.dialect.DiagramDialectUIServices$1.run(DiagramDialectUIServices.java:221)
at org.eclipse.sirius.common.ui.tools.api.util.EclipseUIUtil.displaySyncExec(EclipseUIUtil.java:337)
at org.eclipse.sirius.diagram.ui.business.internal.dialect.DiagramDialectUIServices.openEditor(DiagramDialectUIServices.java:234)
at org.eclipse.sirius.diagram.ui.business.internal.dialect.DiagramDialectUIServices.openEditor(DiagramDialectUIServices.java:187)
at org.eclipse.sirius.ui.business.internal.dialect.DialectUIManagerImpl.openEditor(DialectUIManagerImpl.java:94)
at my.design.Validation.validateAll(Validation.java:415)
at org.eclipse.acceleo.query.runtime.impl.JavaMethodService.internalInvoke(JavaMethodService.java:162)
at org.eclipse.acceleo.query.runtime.impl.AbstractService.invoke(AbstractService.java:135)
at org.eclipse.acceleo.query.runtime.impl.EvaluationServices.callService(EvaluationServices.java:129)
at org.eclipse.acceleo.query.runtime.impl.EvaluationServices.call(EvaluationServices.java:172)
at org.eclipse.acceleo.query.runtime.impl.EvaluationServices.callOrApply(EvaluationServices.java:208)
at org.eclipse.acceleo.query.parser.AstEvaluator.caseCall(AstEvaluator.java:189)
at org.eclipse.acceleo.query.ast.util.AstSwitch.doSwitch(AstSwitch.java:119)
at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:53)
at org.eclipse.emf.ecore.util.Switch.doSwitch(Switch.java:69)
at org.eclipse.acceleo.query.parser.AstEvaluator.eval(AstEvaluator.java:109)
at org.eclipse.acceleo.query.runtime.impl.QueryEvaluationEngine.eval(QueryEvaluationEngine.java:52)
at org.eclipse.sirius.common.acceleo.aql.business.internal.AQLSiriusInterpreter.evaluateExpression(AQLSiriusInterpreter.java:218)
at org.eclipse.sirius.common.acceleo.aql.business.internal.AQLSiriusInterpreter.evaluate(AQLSiriusInterpreter.java:197)
at org.eclipse.sirius.tools.internal.interpreter.SessionInterpreter.evaluate(SessionInterpreter.java:179)
at org.eclipse.sirius.common.tools.api.interpreter.IInterpreter.evaluateBoolean(IInterpreter.java:164)
at org.eclipse.sirius.business.internal.metamodel.description.validation.operations.ValidationRuleOperations.checkRule(ValidationRuleOperations.java:61)
at org.eclipse.sirius.diagram.tools.api.validation.constraint.AbstractDDiagramConstraint.getFailingRulesFromCollection(AbstractDDiagramConstraint.java:187)
at org.eclipse.sirius.diagram.tools.api.validation.constraint.AbstractDDiagramConstraint.getFailingRules(AbstractDDiagramConstraint.java:138)
at org.eclipse.sirius.diagram.tools.api.validation.constraint.AbstractDDiagramConstraint.validate(AbstractDDiagramConstraint.java:62)
at org.eclipse.emf.validation.internal.util.JavaConstraintParser$ConstraintAdapter.validate(JavaConstraintParser.java:80)
at org.eclipse.emf.validation.internal.service.AbstractValidator.evaluateConstraints(AbstractValidator.java:241)
at org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:264)
at org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:211)
at org.eclipse.emf.validation.internal.service.BatchValidator.doValidate(BatchValidator.java:149)
at org.eclipse.emf.validation.internal.service.AbstractValidator.validate(AbstractValidator.java:147)
at org.eclipse.emf.validation.internal.service.AbstractValidator.validate(AbstractValidator.java:126)
at org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:1)
at org.eclipse.sirius.diagram.ui.part.ValidateAction.validate(ValidateAction.java:190)
at org.eclipse.sirius.diagram.ui.part.ValidateAction.access$0(ValidateAction.java:179)
at org.eclipse.sirius.diagram.ui.part.ValidateAction$2.run(ValidateAction.java:159)
at org.eclipse.sirius.diagram.ui.internal.providers.SiriusValidationProvider$1.run(SiriusValidationProvider.java:75)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
at org.eclipse.sirius.diagram.ui.internal.providers.SiriusValidationProvider.runWithConstraints(SiriusValidationProvider.java:84)
at org.eclipse.sirius.diagram.ui.part.ValidateAction.runValidation(ValidateAction.java:155)
at org.eclipse.sirius.diagram.ui.part.ValidateAction$1.run(ValidateAction.java:112)
at org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation.execute(WorkspaceModifyDelegatingOperation.java:71)
at org.eclipse.ui.actions.WorkspaceModifyOperation.lambda$0(WorkspaceModifyOperation.java:110)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2292)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2317)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:131)
at org.eclipse.sirius.diagram.ui.part.ValidateAction.run(ValidateAction.java:114)
at org.eclipse.sirius.diagram.ui.tools.internal.commands.ValidateDiagramCommand.execute(ValidateDiagramCommand.java:43)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:97)
at sun.reflect.GeneratedMethodAccessor63.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:253)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:438)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:449)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:475)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4213)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4030)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1158)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1047)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
Caused by: java.lang.IllegalStateException: Cannot activate read/write transaction in read-only transaction context
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.acquire(TransactionalEditingDomainImpl.java:576)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.activate(TransactionalEditingDomainImpl.java:508)
at org.eclipse.emf.transaction.impl.TransactionImpl.start(TransactionImpl.java:204)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorSessionListenerDelegate.reloadPalette(DDiagramEditorSessionListenerDelegate.java:259)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorSessionListenerDelegate.run(DDiagramEditorSessionListenerDelegate.java:193)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.notify(DDiagramEditorImpl.java:1394)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.setInput(DDiagramEditorImpl.java:1977)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEditor.java:346)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init(DiagramEditor.java:654)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.init(DiagramDocumentEditor.java:128)
at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramEditorImpl.init(DDiagramEditorImpl.java:569)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:353)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:340)
... 149 more
!SUBENTRY 1 org.eclipse.ui 4 0 2022-02-28 10:18:29.515
!MESSAGE Cannot activate read/write transaction in read-only transaction context
!STACK 0
Re: Validating all diagrams in a session [message #1850422 is a reply to message #1850395] |
Wed, 02 March 2022 13:39 |
Hello Ali,
Thanks for your reply. I did not know so much about EMF validation and IStatus, I will look at this.
Btw, I found a way to validate all diagrams. For the future users, I am trying to tell how to do that. To overcome the "Cannot activate read/write transaction in read-only transaction context" exception, I ran DialectUIManager.INSTANCE.openEditor(session, representation, new NullProgressMonitor()); command via using TransactionalEditingDomain class. During the validation of a diagram, if I found any problem, then I stopped traversing diagrams. I am sending a short version of the related code as a service function. As well, I close the diagrams after the validation if they have not been opened yet.
Lastly, if I call this function under a "validation" operation that is defined in .odesign file, then I encounter an exception that I could not figure out yet. However, there is no problem if I call it under an "operation action" menu.
public static boolean validateAllDiagrams(EObject self) {
markerControl = false;
HashSet<ISiriusEditor> openedEditorSet = new HashSet<ISiriusEditor>();
String sessionPath = session.getSessionResource().getURI().toPlatformString(true);
TreeIterator<EObject> allTree = self.eAllContents();
for(ISiriusEditor e: SessionUIManager.INSTANCE.getUISession(session).getSiriusEditors()) {
if(e instanceof DDiagramEditor)
openedEditorSet.add(e);
IPath path = new Path(sessionPath);
IFile repFile = ResourcesPlugin.getWorkspace().getRoot().getFile(path);
while(allTree.hasNext()) {
EObject i = allTree.next();
Collection<DRepresentation> representationList = DialectManager.INSTANCE.getRepresentations(i, session);
for(DRepresentation dr: representationList) {
if(dr instanceof DDiagram) {
if(!dr.getName().equals("TitleOfMyCurrentDiagram")) {
TransactionalEditingDomain domain = TransactionUtil.getEditingDomain(i);
RecordingCommand r = new RecordingCommand(domain) {
protected void doExecute() {
IEditorPart editorPart = DialectUIManager.INSTANCE.openEditor(session, dr, new NullProgressMonitor());
DialectEditor de = (DialectEditor) editorPart;
de.validateRepresentation();
// instead of calling validateRepresentation function, below code works too.
// WorkbenchPartDescriptor workbenchPartDescriptor = new WorkbenchPartDescriptor(editorPart.getSite().getId(), editorPart.getClass(), editorPart.getSite().getPage());
// ValidateAction va = new ValidateAction(workbenchPartDescriptor);
// va.run();
try {
IMarker arr[] = repFile.findMarkers(IMarker.MARKER, true, IResource.DEPTH_INFINITE);
if(arr.length > 0)
markerControl = true;
} catch (CoreException e) {
e.printStackTrace();
if(!markerControl){
if(!openedEditorSet.contains(editorPart)){
DialectUIManager.INSTANCE.closeEditor(editorPart, false);
r.execute();
if(markerControl == true){
return false;
return true;
[Updated on: Wed, 02 March 2022 13:41] Report message to a moderator
FUDForum. Page generated in 0.03598 seconds
