Eclipse on Virtual Box debug on embedded [message #1850067] |
Mon, 14 February 2022 15:24  |
Hi!
I have built a Virtual Box guest with Ubuntu in order to compile some Linux libraries and create a program which handles audio using Eclipse.
I have managed to create the executable, everything looks fine, but when I try to debug that program into my embedded device, the connection doesn't work properly. I have put my virtual box, my host and the embedded device in the same IP Lan, but that doesn't work neither.
How should I configure my virtual box and my Eclipse in order to be able to debug right away? May it be a firewall problem and how can I check it if you know?
Ander.
Re: Eclipse on Virtual Box debug on embedded [message #1850083 is a reply to message #1850073] |
Tue, 15 February 2022 08:27   |
Yes, I have made an image which has the libraries of audio I use to compile my program in Eclipse and I have also checked the proper audio hardware driver on my target device. The problem is with the communication between the virtual machine and the embedded system. Does anyone know how do I have to configurate everything (VirtualBox , Eclipse and emebedded) in order to be able to debug my program? I have tried to put all the devices in same IP group, but they can't communicate. Any idea?
FUDForum. Page generated in 0.07746 seconds
