Searching for a guide for Maven/Gradle builds and EMF(-based) frameworks [message #1849968] |
Thu, 10 February 2022 00:48 |
Ricardo \\\"CaWal\\\" Cacheta Waldemarin Messages: 29 Registered: January 2013 |
Hello!
First of all, I must say that EMF and other EMF-based frameworks are amazing and I really want to use them more. However, I always had problems to use them in applications outside the Eclipse IDE.
In my last project, for my PhD degree, I used EMF, Xtext and ATL implement a "framework" for model-based development of domain specific web services (JAX-RS-based). The EMF-based frameworks gave me some headaches until I got Maven working (circa 2019). Having proved my point, I passed to other PhD activities and the project was frozen for the last few years.
Nowadays I want to update the code and open my project for community use, but all my builds are broken. In this sense, i use Maven both to i) build the model-based infrastructure defined for the development of these domain -speciific services, and 2) to build the generated services as well. (Both the support infrastructure and the services share EMF metamodels and Xtext DSLs).
I've never found a comprehensive and updated guide to use EMF-based technologies with maven builds. Do it exists? EMF and related frameworks are amazing, but I think the lack of a better/easier/searchable documentation hinders the best use of them,.
Thanks in advance.
Re: Searching for a guide for Maven/Gradle builds and EMF(-based) frameworks [message #1849992 is a reply to message #1849968] |
Thu, 10 February 2022 13:28 |
Pavel Vlasov Messages: 7 Registered: March 2013 |
My understanding of the question is that the goal is to be able to use the model jars in non-OSGi environment, say SpringBoot microservices, and have Maven-style dependencies management, i.e. pom.xml.
If this is the case, I have several examples of interdependent models built with "pure Maven" and published to Maven Central.
* Ncore model - the base of all other models below - https://github.com/Nasdanika/core/tree/master/ncore
* A number of intermediate models, you can find a list here and then navigate to the generated model documentation on the site and to the sources on GitHub - https://docs.nasdanika.org/index.html#products-overview
* Engineering Model - depends on the above models - https://github.com/Nasdanika/engineering/tree/main/model
The above examples uses old EMF dependencies because I need Java 8 compatibility for now. You can look up latest versions at Maven Central and upgrade.
By the way, the web site itself (https://docs.nasdanika.org/) was generated from an application model, which was generated from the engineering model with generated Ecore documentation "mounted" to it - in case you are interested in generating model documentation. A link to the source is in the site footer.
[Updated on: Thu, 10 February 2022 13:52] Report message to a moderator
FUDForum. Page generated in 0.04494 seconds
