Re: Acceleo issue- SSL Handshake Exception [message #1849959 is a reply to message #1849942] |
Wed, 09 February 2022 19:22 |
Ed Willink Messages: 7681 Registered: July 2009 |
Acceleo is multiple plugins and any replacement will probably be similar.
If you are already using Acceleo, then I recommnd that you stick with it. It is very stable so all you have to do is sort out a 'small' releng problem. Moving to anything else will probably be a much larger releng problem quite apart from the migration difficulties.
(A small, albeit awkward, releng problem is not by itself a good reason to change horses. You want to have useful demonstrable technical benefits to outweigh the pain of a change.)
For my own work I use a mix of Xtend string-template favoured Java and straight Java but with most of the heavy lifting performed as M2M rather than M2T. Unfortunately Xtend appears to be heading towards EOL so I wouldn't recommend migrating to it.
Perhaps JET has the best future prospects since it is an important part of EMF. However it is a much older technology.
It is possible to use QVTo/QVTr for M2T, however there are some rough edges that need smoothing off before I can recommend them.
Ed Willink
[Updated on: Wed, 09 February 2022 19:57] Report message to a moderator
FUDForum. Page generated in 0.38719 seconds
