Home » Modeling » Papyrus » Documentation not showing in HTML
Documentation not showing in HTML [message #1849659] Fri, 28 January 2022 06:14 Go to next message
Hi!
I'm trying Papyrus and really enjoying it.
One of the features I most need is the "Export to HTML". When browsing the exported HTML I can find the diagrams, packages but the documentations. I would like to click (select) an element in the diagram or the explorer and have the documentation shown.
There is a bottom frame empty blank that seems to be the place where the documentation would be shown.
Probably is something I'm doing wrong, but can't figure out or find out information.
I'm using Papyrus 4.21.0 in a Archlinux machine.
Let me know if there are more information I should provide.
Thanks a lot!
Re: Documentation not showing in HTML [message #1849731 is a reply to message #1849659] Mon, 31 January 2022 08:01 Go to previous messageGo to next message
This function only works for the model root, the top most model element within your model.
Re: Documentation not showing in HTML [message #1849736 is a reply to message #1849731] Mon, 31 January 2022 11:16 Go to previous messageGo to next message
And sometimes it helps performing
    save all
    F5
before generating HTML.
Re: Documentation not showing in HTML [message #1849810 is a reply to message #1849659] Thu, 03 February 2022 08:00 Go to previous messageGo to next message
Hi Rafael,
I observed the same behavior than you with Papyrus 2022-03-M2, but I also notices a bad content for the ModelExplorer on the generated html. Did you observe the same bug (see image in attachment)?
/Vincent
  • Attachment: snapshot.PNG
    (Size: 77.15KB, Downloaded 200 times)
Re: Documentation not showing in HTML [message #1853958 is a reply to message #1849810] Mon, 25 July 2022 16:15 Go to previous messageGo to next message
I have also problems with exporting as html.
Few days back it works. But today nothing it don't. It export only diagrams, and I noticed that not all diagrams are exported. When i choose exporting as images Then all diagrams are exported....
Re: Documentation not showing in HTML [message #1853992 is a reply to message #1853958] Wed, 27 July 2022 04:56 Go to previous message
I When looking more into the diagrams that are not exported i figured out that there was a naming issue between some state diagrams.
I don't know why exporting as images worked out well but the HTML version not. But at least for now i have everything working again....
Previous Topic:Import Enterprise Architect XMI/XML file
Next Topic:Nightly builds of Papyrus SW designer
Current Time: Thu May 22 09:41:36 EDT 2025
Powered by FUDForum. Page generated in 0.07423 seconds
