| Functional blocks without ECCs [message #1849558] |
Tue, 25 January 2022 05:19  |
Hello, I'm new to 4Diac and IEC 61499.
I have a question, where can I find the description of the functional block's behavior when it does not have ECC?
As an example, for E_SR I can go to the file located in the
"Type Library/events/E_SR.fbt", then I can find in this file (which is in XML format) a tag "BasicFB".
However, for E_DELAY this description doesn't exist (there is only a tag called "Service").
Irman
| Re: Functional blocks without ECCs [message #1849570 is a reply to message #1849558] |
Tue, 25 January 2022 16:12  |
Hi Irman,
these are so called service interface function blocks. Such function blocks are device specific and do not have an implementation in IEC 61499. Some of these have a description with service sequence diagrams. But us 4diac IDE just recently got a somehow useable service sequence editor many of the service interface FBs don't have a sequence diagram. For some of the FBs you can find some explanation in the fields of the type information property sheet and in the comments of the different pins.
I hope this helps.
Alois
FUDForum. Page generated in 0.06379 seconds
