Home » Eclipse Projects » GEF » is it possible to attach two shapes together without edge?
is it possible to attach two shapes together without edge? [message #1849284] Tue, 11 January 2022 06:32 Go to next message
I am wondering if I could set two shapes, say a box and a diamond together without any edge in between?
Something like in the attachment.
I tried width, height, defaultdist, etc. nothing worked
Fang
Re: is it possible to attach two shapes together without edge? [message #1849297 is a reply to message #1849284] Wed, 12 January 2022 01:58 Go to previous messageGo to next message
Hello Fang,
For that purpose, you can use e.g. the nodesep attribute, see the attached screenshot.
Hope that helps,
Tamás
Re: is it possible to attach two shapes together without edge? [message #1849299 is a reply to message #1849284] Wed, 12 January 2022 02:36 Go to previous messageGo to next message
You will have to use polygon shape.
Re: is it possible to attach two shapes together without edge? [message #1849341 is a reply to message #1849297] Thu, 13 January 2022 04:06 Go to previous messageGo to next message
HiTamás,
Thanks for the advice.
I've tried nodesep.
I need some shapes separated with gap and some without(for example in attachment 1), but nodesep will stick everything together.
I tried using "subgraph" (as seen in attachment 2), it didn't work either.
Do you have any better solutions for this?
Many thanks
Fang
  • Attachment: expected.png
    (Size: 3.52KB, Downloaded 129 times)
  • Attachment: result.png
    (Size: 19.33KB, Downloaded 125 times)
Re: is it possible to attach two shapes together without edge? [message #1849342 is a reply to message #1849299] Thu, 13 January 2022 04:08 Go to previous message
Hi Alexander,
Thanks for the help.
Could you elaborate a bit more how to set the parameters for the polygon to make this kind of shape?
I've got no clue.
Many thanks
Fang
Previous Topic:Circle shape is shown as oval, anyone encountered this?
Next Topic:how to save and import the png within GEF?
Current Time: Sun May 25 02:03:35 EDT 2025
Powered by FUDForum. Page generated in 0.03813 seconds
