Home » Modeling » M2T (model-to-text transformation) » problem with remove method of xpand(problem with remove method of xpand)
problem with remove method of xpand [message #1848966] Mon, 27 December 2021 13:03 Go to next message
Mera Mera is currently offline Mera MeraFriend
Hi all,
«LET (List[type]){} AS list»
«FOREACH play AS e»
«play .add(e) -> ""»
«ENDFOREACH-»
«IF !list.isEmpty»
«FOREACH list AS out ITERATOR i»
«out.name»
«list .remove(out) -> ""»
«ENDFOREACH»
«ENDIF»
«ENDLET»
when i use the remove method i have an exception as see attached:
java.util.ConcurrentModificationException
at java.base/java.util.ArrayList$Itr.checkForComodification(ArrayList.java:1013)
at java.base/java.util.ArrayList$Itr.next(ArrayList.java:967)
at org.eclipse.internal.xpand2.ast.ForEachStatement.evaluateInternal(ForEachStatement.java:117)
at org.eclipse.internal.xpand2.ast.Statement.evaluate(Statement.java:41)
at org.eclipse.internal.xpand2.ast.IfStatement.evaluateInternal(IfStatement.java:93)
at org.eclipse.internal.xpand2.ast.ForEachStatement.evaluateInternal(ForEachStatement.java:121)
at org.eclipse.internal.xpand2.ast.LetStatement.evaluateInternal(LetStatement.java:66)
please help me
thank's
Re: problem with remove method of xpand [message #1848968 is a reply to message #1848966] Mon, 27 December 2021 14:25 Go to previous messageGo to next message
Not sure about the exposition in Xpand but it looks like a standard Java problem.
You cannot modify a collection while you are iterating over it with incurring a risk/probablility of a CME.
If you cannot restructure to avoid it, the easiest workaround is to iterate over an ArrayList copy.
If the iteration is over a list, it can be effective to reverse iterate so that changes occur after the cursor.
Or for a list you can forward iterate an index and loop so long as the index is smaller than the size.
Sometimes you can use a list iterator and its prune() method.
Alternatively maintain a worklist/set and loop for as long as new work was found.
Ed Willink
Re: problem with remove method of xpand [message #1848974 is a reply to message #1848966] Mon, 27 December 2021 18:38 Go to previous messageGo to next message
Thanks Ed for the quick response,
in my "code generation" project I use an xpand template, Arraylist does not work with Xpand, and for deletion the Xpand syntax as follows:
removeAll (Collection) and remove (Object) but I don't understand their uses with exceptions
SVP example of use on lists and method of deletion with Xpand
Thank's
Re: problem with remove method of xpand [message #1848978 is a reply to message #1848974] Mon, 27 December 2021 20:12 Go to previous messageGo to next message
I'm not sure that I have ever used Xpand; just Xtend that supersedes it. Even in Xtend, I try to use only the Xpand-based String templates; the rest I do in Java whose tooling is more predictable.
There is surely an Xpand escape to Java capability. Use it / practice in Java.
Migrate to Xtend. Xpand is dead; https://projects.eclipse.org/projects/modeling.m2t.xpand shows no release for 5.5 years and no commits in the last year. Expect problems with Java 11.
Ed Willink
Re: problem with remove method of xpand [message #1849000 is a reply to message #1848978] Tue, 28 December 2021 22:13 Go to previous message
how to remove a traversed item from a browsed list so as not to be repeated
Previous Topic:problem with oclIsKindOf()
Next Topic:getLabel() behavior
Current Time: Mon May 23 15:23:07 GMT 2022
Powered by FUDForum. Page generated in 0.06103 seconds
