Home » Newcomers » Newcomers » Eclipse Plugin replace(Plugin update with the same Version?)
Eclipse Plugin replace [message #1848795] Fri, 17 December 2021 11:15 Go to next message
Dirk Stephan is currently offline Dirk StephanFriend
Hello all,
I need your help.
My knowledge about Eclipse is very less.
A Plugin vendor have the Log4Shell leak in his plugin.
Now we get a new plugin. But it is the same version like the last and Eclipse says that it exist and couldn“t install again.
What can I do to install the new plugin?
Many thanks
Kind Regards
Dirk
Re: Eclipse Plugin replace [message #1848803 is a reply to message #1848795] Fri, 17 December 2021 14:31 Go to previous message
If a plugin is changed it must also change the version so that one can update to that new version. So the vendor must provide a new plugin with a new version.
Ed Merks
Previous Topic:Unable to launch latest Eclipse app
Next Topic:Java End of Life
Current Time: Thu May 26 23:19:52 GMT 2022
Powered by FUDForum. Page generated in 0.07308 seconds
