Home » Newcomers » Newcomers » Unable to configure Eclipse Debug for Gradle Project(Unable to configure Eclipse Debug for Gradle Project)
Unable to configure Eclipse Debug for Gradle Project [message #1848769] Thu, 16 December 2021 11:26 Go to next message
Roopika Chandra Shekar is currently offline Roopika Chandra ShekarFriend
Hi Team,
I am working as a Software Developer, and my project requirement is to Setup Marquez tool by using any IDE. Marquez tool is mainly used for Data Lineage
It has the main module named marquez with submodules present in it. The build tool used is gradle.
I have to basically work on the API module.
Main module has build.gradle file present also the Submodule API also has build.gradle file present.
I have cloned the submodule api as import existing gradle project into eclipse and setup the code base which is up and running.
But I am facing issues while launching the debug, Have attached the code base, the project runs on port 8080. attached the debug configuration as well and error while launching debug. "Failed to connect to remote VM. Connection timed out.
org.eclipse.jdi.TimeoutException"
Also followed multiple resolutions for solving the issue but still unable to resolve it.
Followed "https://gist.github.com/brightzheng100/c0a7cb947649ea5c79631402625be69c"
Re: Unable to configure Eclipse Debug for Gradle Project [message #1848782 is a reply to message #1848769] Thu, 16 December 2021 16:40 Go to previous message
If your question is about BuildShip, ask here:
https://discuss.gradle.org/c/help-discuss/buildship/20
Ed Merks
Previous Topic:How to apply bug fix to current release
Next Topic:Unable to launch latest Eclipse app
Current Time: Sat May 21 03:44:15 GMT 2022
Powered by FUDForum. Page generated in 0.02708 seconds
