Home » Newcomers » Newcomers » Eclipse for C++ won't start on Ubuntu 20.04
Eclipse for C++ won't start on Ubuntu 20.04 [message #1848481] Sat, 04 December 2021 02:31 Go to next message
Josh Levin is currently offline Josh LevinFriend
I installed downloaded and extracted `Eclipse IDE for C/C++ Developers` from https://www.eclipse.org/downloads/packages/ (The Linux x86_64 version). When I try to run the eclipse binary, I get a popup:
An error has occurred. See the log file
/home/josh/Downloads/eclipse-cpp/eclipse/configuration/1638583987805.log.
That log file is attached.
I followed the advice in the sticky and modified the eclipse.ini file to point to an Oracle JDK 11 binary. It is attached.
How can I fix this? I'll note that I'm on Ubuntu 20.04. Eclipse IDE for Java Developers works out of the box. All I have to do is download the tarball, extract it, and run it.
Re: Eclipse for C++ won't start on Ubuntu 20.04 [message #1848484 is a reply to message #1848481] Sat, 04 December 2021 15:24 Go to previous messageGo to next message
You must have edited the eclipse.ini for it to contain
-vm
/usr/local/bin/java11-oracle
I thought the C/C++ package came packaged with a JRE. Does the folder /usr/local/bin/java11-oracle contain the java executable file? This should point at a folder with the executable...
Ed Merks
Re: Eclipse for C++ won't start on Ubuntu 20.04 [message #1848488 is a reply to message #1848481] Sat, 04 December 2021 16:30 Go to previous messageGo to next message
Tauno Voipio is currently offline Tauno VoipioFriend
I suggest that you delete the Eclipse installation, download the Eclipse installer for Linux and use it to install the main system. Remember to update the installer before using it.
Check that your Ubuntu installation has the build-essential Linux package installed.
Tauno Voipio
Re: Eclipse for C++ won't start on Ubuntu 20.04 [message #1848494 is a reply to message #1848488] Sun, 05 December 2021 00:14 Go to previous message
So it's fixed. As it turns out, I somehow managed to get an old download link (no idea where from).
Previous Topic:Eclipse 2021-06 Installation Issue
Next Topic:Hi I need Help I USe Oracle for Web and Java Devs
Current Time: Sun Nov 27 02:57:39 GMT 2022
Powered by FUDForum. Page generated in 0.04459 seconds
