Problems migrating from eclipselink 2.7.8 to 2.7.9 [message #1847975] |
Mon, 15 November 2021 21:32 |
Dave Brosius Messages: 34 Registered: July 2009 |
Member |
Hi folks we've had code running on various versions of eclipse link up thru 2.7.8 that worked fine for using session customizers to inject fields as part of transactions. In 2.7.9 something seems to have broken. Was there any changes around this area that i can look into?
We do (roughly):
ReturningPolicy rp = new ReturningPolicy();
rp.addFieldForInsertReturnOnly(table + "." + JPAEntityUtils.getPhysicalColumnName(doClz, Updateable.CREATE_DATE), Date.class);
rp.addFieldForInsertReturnOnly(table + "." + JPAEntityUtils.getPhysicalColumnName(doClz, Updateable.UPDATE_DATE), Date.class);
rp.addFieldForUpdate(table + "." + JPAEntityUtils.getPhysicalColumnName(doClz, Updateable.UPDATE_DATE), Date.class);
descriptor.setReturningPolicy(rp);
where we do:
create or replace trigger %{TRIGGER_NAME}
before insert or update
on %{BASE_TABLE_NAME}
FOR EACH ROW
BEGIN
:NEW.%{UPDATE_TS_COLUMN} := %{SYSDATE_REFERENCE};
IF INSERTING THEN
:NEW.%{CREATE_TS_COLUMN} := %{SYSDATE_REFERENCE};
END IF;
end;
The issue is, now, when update happens, we clear out the create date column. Setting of the create date should only happen on the create, not update. If we roll back to 2.7.8 it works as it should.
FUDForum. Page generated in 0.03738 seconds
