Can't connect to remote host using remote debugging settings [message #1847535] |
Sun, 31 October 2021 13:45 |
Artem Kostin Messages: 3 Registered: October 2021 |
I installed Eclipse IDE for C/C++ Developers (includes Incubating components)
Version: 2021-09 (4.21.0)
Build id: 20210910-1417
OS: Linux, v.5.4.0-89-generic, x86_64 / gtk 3.22.30
Java vendor: Oracle Corporation
Java runtime version: 16.0.2+7-67
Java version: 16.0.2.
I have small test C project for arm platform (remote arm board with Linux installed, OpenSSH_8.7p1, OpenSSL 1.1.1l 24 Aug 2021).
While trying to setup Run->Debug Configurations:
1. C/C++ Remote Application
2. Main, project name test1.
3. Connection->New->SSH host.
4. Host: arm-host (resolved, no network issues), user root, public key based authentication (or password based, no matter).
Then I press Browse button near Remote absolute file path.. and get com.jcraft.jsch.JSchException: session is down error.
On the target board I see:
channel_by_id: 0: bad id: channel free
Disconnecting user root dev-pc port 38580: data packet referred to nonexistent channel 0.
in the plugins:
Eclipse Orbit JSch 0.1.55.v20190404-1902 com.jcraft.jsch
Eclipse.org JSch Core 1.3.900.v20200422-1935 org.eclipse.jsch.core
Eclipse PTP JSch Remote Support 1.0.0.202109011318 org.eclipse.remote.jsch.core
Eclipse.org JSch UI 1.4.0.v20210426-0843 org.eclipse.jsch.ui
Eclipse PTP JSch UI Remote Support 1.0.0.202109011318 org.eclipse.remote.jsch.ui
look like latest versions.
Can I get help with resolving this connection issue?
Thanks!
FUDForum. Page generated in 0.04175 seconds
