Home » Newcomers » Newcomers » Help for running Eclipse on a legacy Mac OS (10.9)
Help for running Eclipse on a legacy Mac OS (10.9) [message #1847381] Mon, 25 October 2021 18:07 Go to next message
Ivan Frey is currently offline Ivan FreyFriend
I have an old iMac running Mac OS 10.9. I was curious to see if I could get Eclipse to run on it. I've been trying various versions of Eclipse. The last version I was able to run was 3.6. I read that 4.4 should be able to run, but I get an error which is beyond my level of competence,
If this system is too old for anybody to bother, I understand.
[Updated on: Mon, 25 October 2021 18:09]
Report message to a moderator
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847384 is a reply to message #1847381] Mon, 25 October 2021 18:46 Go to previous messageGo to next message
Tauno Voipio is currently offline Tauno VoipioFriend
The Java on your computer may be 32 bits.
The current Eclipse versions need 64 bit Java to run.
The hardware running OS X 10.9 should be OK for 64 bits.
Tauno Voipio
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847399 is a reply to message #1847384] Tue, 26 October 2021 01:58 Go to previous messageGo to next message
Because Apple doesn't support an OS higher than Lion (10.7) on my iMac, I installed a modified version of 10.9 (Mavericks) on my machine.
64 bit apps appear to run just fine. I don't understand why Eclipse 4.4 won't run, because it was certified at the time to run on 10.9.
When I get home I will attach the metadata.log file.
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847429 is a reply to message #1847384] Tue, 26 October 2021 22:00 Go to previous messageGo to next message
Current versions of Eclipse require 10.10. Do you know the youngest version of Eclipse to run on 10.9?
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847440 is a reply to message #1847429] Wed, 27 October 2021 08:20 Go to previous messageGo to next message
Get Java JDK from Java pages. Remember to select 64 bit version, if there are choices. Version 8 (also called 1.8) should fit in well, and the information is a bit fuzzy, version 11 could.
The Java version limits what release of Eclipse you can run.
Please use the Eclipse installer to set Eclipse up.
Tauno Voipio
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847455 is a reply to message #1847440] Thu, 28 October 2021 01:08 Go to previous messageGo to next message
The current version of the Eclipse installer requires 10.10 and earlier versions crash.
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847468 is a reply to message #1847455] Thu, 28 October 2021 09:53 Go to previous messageGo to next message
Have you attempted to install Java 11?
It might work. Sorry, I do not have an OS X older than El Capitan, anymore.
Tauno Voipio
Re: Help for running Eclipse on a legacy Mac OS (10.9) [message #1847491 is a reply to message #1847468] Fri, 29 October 2021 00:38 Go to previous message
Yes, I installed Java 11.
Previous Topic:A persistent start has been called on bundle
Next Topic:How to make multi user work on 1 server
Current Time: Tue May 24 17:49:48 GMT 2022
Powered by FUDForum. Page generated in 0.03099 seconds
