Home » Language IDEs » C / C++ IDE (CDT) » Where did ":" come from ?(linking library )
Where did ":" come from ? [message #1847292] Thu, 21 October 2021 22:31 Go to next message
Anne Ranch is currently offline Anne RanchFriend
Member
To link to libbluetooth.a library I have to add ": " to option.
Why?
Invoking: GCC C++ Linker
g++ -L/usr/lib/x86_64-linux-gnu -v -o "TEST_BT" ./src/TEST_BT.o -l:libbluetooth.a
Re: Where did ":" come from ? [message #1847298 is a reply to message #1847292] Fri, 22 October 2021 06:39 Go to previous messageGo to next message
David VavraFriend
Learn the linker options
https://gcc.gnu.org/onlinedocs/gcc-11.2.0/gcc/Link-Options.html
scroll down to "-llibrary"
From the man page for ld:
-l namespec
If namespec is of the form :filename, ld will search the library path for a file called
filename, otherwise   it will search the library path for a file called libnamespec.a
Full doumentation for linker (ld-2.37)
https://sourceware.org/binutils/docs/ld/
[Updated on: Fri, 22 October 2021 07:47]
Report message to a moderator
Re: Where did ":" come from ? [message #1847347 is a reply to message #1847298] Sun, 24 October 2021 13:20 Go to previous message
apollos dada is currently offline apollos dadaFriend
Hi, thanks for sharing the link
Previous Topic:Issues to build a project
Next Topic:How to calibrate a simulation without teleports
Current Time: Tue Apr 16 18:39:40 GMT 2024
Powered by FUDForum. Page generated in 1.45486 seconds
