Home » Eclipse Projects » Eclipse Scout » PlannerField - Error when navigating(The following exception is thrown when navigating or reloading the PlannerField)
PlannerField - Error when navigating [message #1847273] Thu, 21 October 2021 10:58 Go to next message
When trying to reload or navigating the PlannerField, the following exception is thrown. Navigation and reloading of the form are done through
execViewRangeChanged
calling
loadResources()
Seems that the error occurs because i have the same activities visibles on the old view range and the new one.
Does anyone has an idea how to get rid of it ?
2021-10-21 14:48:05,362 WARN  [scout-model-thread-16 Transforming response to JSON] org.eclipse.scout.rt.ui.html.UiSession.lambda$6(UiSession.java:848) - Error while transforming response to JSON: JsonResponse [#43, adapters: 0, events: 4, buffered events adapters: 1] - MDC[principal=szakou, uiSession=1:f1tp4i94k8d4dtqqqqeb7ir7647kvq715tj7c0m1mdoqt5pnlfg, scoutSession=1ar4q4d1nbie6er90hlmnk9ovi9rmbcq6tr6a0fta1v42jmtce4p, jobName=Transforming response to JSON, cid=YF3Zh3Yn9SB/45]
java.lang.IllegalStateException: Cell already has an id. Activity[Idrissa Kara]
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonPlanner.createCellId(JsonPlanner.java:244)
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonPlanner$P_NewCellIdProvider.getId(JsonPlanner.java:580)
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonPlanner$P_NewCellIdProvider.getId(JsonPlanner.java:1)
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonActivity.toJson(JsonActivity.java:40)
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonResource.cellsToJson(JsonResource.java:50)
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonResource.toJson(JsonResource.java:41)
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonPlanner.handleModelResourcesInserted(JsonPlanner.java:359)
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonPlanner.processEvent(JsonPlanner.java:331)
	at org.eclipse.scout.rt.ui.html.json.basic.planner.JsonPlanner.processBufferedEvents(JsonPlanner.java:324)
	at org.eclipse.scout.rt.ui.html.json.JsonResponse.fireProcessBufferedEvents(JsonResponse.java:353)
	at org.eclipse.scout.rt.ui.html.json.JsonResponse.toJson(JsonResponse.java:286)
	at org.eclipse.scout.rt.ui.html.UiSession.responseToJsonInternal(UiSession.java:827)
	at org.eclipse.scout.rt.ui.html.UiSession.lambda$6(UiSession.java:845)
	at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:227)
	at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxMandatory(TransactionProcessor.java:156)
	at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequired(TransactionProcessor.java:139)
	at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.intercept(TransactionProcessor.java:78)
	at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:222)
	at java.base/java.security.AccessController.doPrivileged(Native Method)
	at java.base/javax.security.auth.Subject.doAs(Subject.java:423)
	at org.eclipse.scout.rt.platform.security.SubjectProcessor.intercept(SubjectProcessor.java:43)
	at org.eclipse.scout.rt.platform.chain.callable.CallableChain.call(CallableChain.java:170)
	at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:158)
	at org.eclipse.scout.rt.platform.context.RunContextRunner.intercept(RunContextRunner.java:38)
	at org.eclipse.scout.rt.platform.job.internal.CallableChainExceptionHandler.intercept(CallableChainExceptionHandler.java:33)
	at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.lambda$0(JobFutureTask.java:106)
	at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
	at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.run(JobFutureTask.java:175)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
	at java.base/java.lang.Thread.run(Thread.java:829)
	at org.eclipse.scout.rt.platform.job.internal.NamedThreadFactory$1.run(NamedThreadFactory.java:63)
Re: PlannerField - Error when navigating [message #1847296 is a reply to message #1847273] Fri, 22 October 2021 02:01 Go to previous messageGo to next message
please check your implementation of execLoadResources. You are probably inserting the same activity multiple times.
Re: PlannerField - Error when navigating [message #1847331 is a reply to message #1847296] Fri, 22 October 2021 12:46 Go to previous message
Thanks for your reply.
You are right, I reviewed the implementation of execLoadResources, and things works well now.
Previous Topic:DND in Scout 11 ( and next Release )
Next Topic:File Drop on a table row no more working ?
Current Time: Sun Jul 20 06:56:40 EDT 2025
Powered by FUDForum. Page generated in 0.06123 seconds
