Home » Eclipse Projects » WindowBuilder » Extending Swing Class - View Properties(Does WindowBuilder understand properties for Extended Class)
Extending Swing Class - View Properties [message #1844996] Sat, 02 October 2021 12:29 Go to next message
My Swing application uses a lot of extended classes so for enable I have a class called JButton4j which extends JButton. This lets me set certain properties by default and make it easier to adopt a standard look.
If I click on one of my Frames which has an instance of JButton on it I see all the properties. However if I click on a JButton4j then I see very few properties.
See attached.
Is this a known issue, a bug or am I failing to do something myself ?
Re: Extending Swing Class - View Properties [message #1846933 is a reply to message #1844996] Sat, 09 October 2021 13:49 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Your screenshot shows more properties for JButton4j than for the JButton. The screenshot contradicts your text.
Re: Extending Swing Class - View Properties [message #1846937 is a reply to message #1846933] Sat, 09 October 2021 14:05 Go to previous messageGo to next message
Sorry for my bad description - what I should have said was that it has the properties listed in the inspector but many values which I had assumed would be present as they are inherited don't seem to be there.
Re: Extending Swing Class - View Properties [message #1846938 is a reply to message #1846933] Sat, 09 October 2021 14:09 Go to previous message
Sorry for my poor description - I should have said I was confused by the missing values for the properties.
Would the source for the button class help.
public class JButton4j extends JButton {
	private static final long serialVersionUID = 1L;
	public JButton4j() {
		setFont(Common.font_btn);
	public JButton4j(Icon icon) {
		super(icon);
	public JButton4j(String text) {
		super(text);
		setToolTipText(text);
	public JButton4j(Action a) {
		super(a);
	public JButton4j(String text, Icon icon) {
		super(text, icon);
	public void setText(String text)
		super.setText(text);
[Updated on: Sat, 09 October 2021 14:11] by Moderator
Report message to a moderator
Previous Topic:Eclipse Marketplace install options (versions)
Next Topic:Window builder fails to install
Current Time: Sat Feb 08 07:47:51 GMT 2025
Powered by FUDForum. Page generated in 0.03372 seconds
