Home » Modeling » TMF (Xtext) » Xtext 2.26.0.M2 is available
Xtext 2.26.0.M2 is available [message #1844965] Fri, 01 October 2021 06:55 Go to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi all,
I am pleased to announce the availability of Xtext 2.26.0.M2.
This is the first version that won't explode with Java 17 thanks to an update to Google Guice 5.0
(run with Java 17 against 8/11 target, running against 17 will follow next year when platform/jdt and other upstream dependencies also support it)
We also did some changes to how recovery builds are scheduled https://github.com/eclipse/xtext-eclipse/issues/1710
Release Notes (WIP) are at https://github.com/eclipse/xtext/blob/website-master/xtext-website/_posts/releasenotes/2022-01-31-version-2-26-0.md
For both we strongly encourage you to test and give feedback.
You can find the milestone at https://download.eclipse.org/modeling/tmf/xtext/updates/milestones/S202110010541/
and http://www.eclipse.org/modeling/download.php?file=/modeling/tmf/xtext/downloads/drops/2.26.0/S202110010541/tmf-xtext-Update-2.26.0.M2.zip
and soon on Maven Central
(suitable mwe verison is 2.12.2.M1 / https://download.eclipse.org/modeling/emft/mwe/updates/milestones/S202108160852/)
Happy Xtexting
Thanks and Regards
Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Fri, 08 October 2021 07:42]
Report message to a moderator
Re: Xtext 2.26.0.M2 is available [message #1845017 is a reply to message #1844965] Sun, 03 October 2021 04:58 Go to previous messageGo to next message
Mirko Raner is currently offline Mirko RanerFriend
That is great news, Christian.
Thanks for all the work that you put into this!
I'll report back if I find anything unexpected after the upgrade.
Re: Xtext 2.26.0.M2 is available [message #1848910 is a reply to message #1845017] Thu, 23 December 2021 08:14 Go to previous messageGo to next message
I just upgraded my project to Xtext 2.26.0.M2 (previously on 2.22.0) and did not run into any issues. In addition to upgrading MWE, moving to Guice 5.0.1 (and removing the no_aop classifier), I also had to fully move to Java 11 (previously Java 9) and update Tycho from 1.7.0 to 2.1.0 (version 2.2.0 and higher turned out to be incompatible with the org.reficio:p2-maven-plugin that I use).
Great job putting this together, Christian. Especially the move to Guice 5 removes a number of persistent headaches for me.
Is there a timeline for the final 2.26.0 release yet?
Re: Xtext 2.26.0.M2 is available [message #1848912 is a reply to message #1848910] Thu, 23 December 2021 09:26 Go to previous message
late jan/beg. febr.
Previous Topic:How can I transform an xtext dsl file to xml?
Next Topic:Strange launch and build issue with XText antlr dependency and Eclipse products
Current Time: Fri Jun 02 05:32:04 GMT 2023
Powered by FUDForum. Page generated in 0.02095 seconds
