Home » Newcomers » Newcomers » packages installation
packages installation [message #1844915] Wed, 29 September 2021 14:19 Go to next message
Nazim Bouamrane is currently offline Nazim BouamraneFriend
Hi!
Except of Java JDK and eclipse, do i have to install any type of basic packages to get started?
Re: packages installation [message #1844918 is a reply to message #1844915] Wed, 29 September 2021 15:40 Go to previous messageGo to next message
No. The Eclipse Installer can even install a JRE for you and the packaged downloads also contain a JRE. You don't need anything else.
Ed Merks
Re: packages installation [message #1844919 is a reply to message #1844918] Wed, 29 September 2021 15:54 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
If by "get started" you mean developing Java applications, then yes, the JDK is still good to have.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: packages installation [message #1844924 is a reply to message #1844919] Wed, 29 September 2021 17:32 Go to previous message
The latest JustJ JREs that are in the Java package, and will be installed by the installer if a JRE/JDK is not available on the machine, have a src.zip, so they are definitely sufficient for "getting started" purposes, including debugging and stepping into the Java runtime source. Of course that's not to say a JDK isn't good to have, it's just not a prerequisite anymore...
Ed Merks
Previous Topic:Eclipse with a new UI in 2021.
Next Topic:"Error: could not create a java virtual machine"
Current Time: Thu Dec 02 15:53:59 GMT 2021
Powered by FUDForum. Page generated in 0.03084 seconds
