Broken looking diagram image exports on Linux [message #1844849] |
Tue, 28 September 2021 06:00 |
Erik Danielsson Messages: 14 Registered: September 2021 |
Hi! Newcomer to Sirius here.
I am having an issue where some diagrams have broken texts when exporting as PDF/PNG/SVG. It only seems to occur on Linux, and the JPG/BMP both look good.
Is there a way to fix this, or is it perhaps a known bug? Worst case: would it be possible to disable these image formats on Linux perhaps?
Thanks in advance!
*The text in these diagrams look normal in the actual diagram
[Updated on: Tue, 28 September 2021 17:43] Report message to a moderator
Re: Broken looking diagram image exports on Linux [message #1844904 is a reply to message #1844849] |
Wed, 29 September 2021 12:46 |
Hi.
I know there can be some diffrences in the font metrics computation depending on the format used (for historical reasons even the various bitmaps formats use different rendering pipelines), but usually it's just a few pixels of difference. I've never seen such a large miscomputation.
* Which versions of Sirius and GMF Runtime are you using?
* Are you on a HiDPI screen?
* Is the font configured for your labels actually present on your system (if it is not, maybe the fallback font chosen is different between the rendering and the export)?
Pierre-Charles
Pierre-Charles David - Obeo
FUDForum. Page generated in 0.02049 seconds
