Home » Modeling » TMF (Xtext) » Change StringConcatenation for grammar tests(Using unix line endings in tests)
Change StringConcatenation for grammar tests [message #1844831] Mon, 27 September 2021 14:00 Go to next message
Horacio Hoyos is currently offline Horacio HoyosFriend
My grammar is intended for unix usage, so we only support unix line endings.
When writing tests, I noticed that I am getting errors related to additional <CR> tokens.
Is there a way I can change the StringConcatenation used by the xtend Junit tests? Or is there another way to change the newline character used by template expressions?
Horacio Hoyos Rodriguez
Kinori Tech
Need professional support for Epsilon, EMF?
Go to: https://kinori.tech
Re: Change StringConcatenation for grammar tests [message #1844833 is a reply to message #1844831] Mon, 27 September 2021 14:50 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
you can either use String.toUnix.... in the tests or something like
		val v = new StringConcatenation("\n")
		v.append('''
		this
		is
		a
		test
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Change StringConcatenation for grammar tests [message #1844870 is a reply to message #1844833] Tue, 28 September 2021 11:48 Go to previous message
Worked perfectly, thanks!
Kinori Tech
Previous Topic:Extending XtextBuilder for two DSLs
Next Topic:Namespace import no longer works since XText 2.21.0
Current Time: Mon Mar 27 23:24:03 GMT 2023
Powered by FUDForum. Page generated in 0.02003 seconds
