Re: indexer not working on *.cpp files [message #1844721 is a reply to message #1844693] |
Thu, 23 September 2021 04:50 |
David Vavra Messages: 1426 Registered: October 2012 |
You need to setup include paths for the Indexer just as you would need to for the compiler.
The Indexer and compiler are completely independent.
The Indexer include paths are set by
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> Entries tab --> CDT UserSettings Entries
For example, you are attempting to include (in GatheringUtils.hpp),
SeekDeepPrograms/SeekDeepProgram/SeekDeepSetUp.hpp
which has to be relative to one of the items in the include path list.
The parser log is saying it couldn't be found.
go the the CDT UserSettings Entries,
- click Add
- select the path type <project>, <workspace>, or <file system>
from the dropdown in the upper right
- enter the directory containing your headers or browse for it
- click OK
I think this only accepts one entry per add.
You will probably need to rebuild the index after setting all of the paths.
You could try using
Project --> Properties --> C/C++ General --> Paths and Symbols
That's supposed to merge telling the compiler and Indexer in one place.
If you do, you will need to enable the CDT Managed Build Settings provider.
Don't use it myself as I rarely use Managed Build Projects.
[Updated on: Thu, 23 September 2021 04:57] Report message to a moderator
Re: indexer not working on *.cpp files [message #1844754 is a reply to message #1844748] |
Fri, 24 September 2021 06:36 |
Not strange at all.
Again, the include paths given to the compiler are not used by the Indexer.
Those are only used when creating Makefiles.
You have to tell the Indexer as well.
The Indexer ONLY uses the paths found in
Many projects don't create makefiles. Some don't even use them.
Whatever the reason for the design decision, it's been like this for years.
You could request an enhancement (using bugzilla)
but I understand interest in maintaining the Indexer has waned.
I could be wrong about that.
OTOH: perhaps you might volunteer?
Not sure what you mean by it found it at one time. Both the .hpp and .cpp logs have:
Unresolved inclusion: <SeekDeepPrograms/SeekDeepProgram/SeekDeepSetUp.hpp> in file:
/Users/nick/hathaway/external/build/pathweaver/develop/pathweaver/src/PathWeaver
/PostWeavingUtils/GatheringUtils.hpp
I see you didn't create a User Entry.
Here's what a typical User Entry looks like in the parser log:
Local Include Search Path:
/opt/farAndAway/includes
You have these options:
- repeat the paths for the Indexer as I've described
- Use Paths and Symbols instead -- it's meant to solve the telling both problem
- Build then let the GCC CDT Build Output Parser discover them
[Updated on: Fri, 24 September 2021 09:50] Report message to a moderator
Re: indexer not working on *.cpp files [message #1844801 is a reply to message #1844798] |
Sun, 26 September 2021 05:14 |
Quote:CDT for years and in the past the parser was always able to determine the headers to parse after building
I think it's the after building part that's important. The Build Output Parser will add
any paths found in the build log to the Indexer list.
If you are now saying, that's not working then look at the log parsing elements it is using. You
may have inadvertently changed them or the log output no longer allows using them.
You should be aware that CDT can parse a header that's opened for editing as long as it doesn't
refer to a header with a path that it doesn't have. The hpp log was generated from what
seems such a header.
The cpp log is still saying (among others):
Unresolved includes (from headers in index):
Unresolved inclusion: SeekDeepPrograms/SeekDeepProgram/SeekDeepSetUp.hpp in file file:/Users/nick/newHathaway/external/build/PathWeaver/develop/PathWeaver/src/PathWeaver/PostWeavingUtils/GatheringUtils.hpp
So, you must in some way add the path where it can be found to the path list used by the Indexer.
[Updated on: Sun, 26 September 2021 05:24] Report message to a moderator
Re: indexer not working on *.cpp files [message #1847495 is a reply to message #1844813] |
Fri, 29 October 2021 04:40 |
Mohith Manoj Messages: 2 Registered: October 2021 |
I am suffering from the exact same issue. In my case the issue is more with header files. Index rebuilding solutions are totally useless. Indexer fails to pick up few of my own header files as well as some of system headers.
To troubleshoot the indexer I first generated the parse log file (sample attached ScrollWheel.log). On lines 11976 and 11977 you can see the indexer reporting unresolved files ParameterValue.h and VariableStepTable.h both of which are in my project and paths to both the files are known to the indexer (log file line number 60). I couldn't go any further than this for I don't know for what reason indexer is unable to resolve the header file even when it is in a known path.
The next step was to run eclipse in debug mode while adding options to get details on what the indexer is doing. I ran the following command in a terminal (Ubuntu).
./eclipse -debug .options
The option file is attached. Then I selected ScrollWheel.c and ScrollWheel.h in the project explorer and ran Index > Freshen All Files. Following is the output I get.
Indexer: start PDOMUpdateTask
Indexer: parsing /LinEmLibrary/library/Widgets/ParameterAdjustment/ScrollWheel.h
Indexer: adding file:/mnt/win_d/Projects/ADS/TV1/LIN/SW/LinEmLibrary/library/Widgets/ParameterAdjustment/ScrollWheel.h
Indexer: processed /LinEmLibrary/library/Widgets/ParameterAdjustment/ScrollWheel.h [97 ms]
Indexer: processed /LinEmLibrary/library/Widgets/ParameterAdjustment/ScrollWheel.h [47 ms]
Indexer: processed /LinEmLibrary/library/Widgets/ParameterAdjustment/ScrollWheel.h [95 ms]
Indexer: parsing /LinEmLibrary/library/Widgets/ParameterAdjustment/ScrollWheel.cpp
Indexer: adding file:/mnt/win_d/Projects/ADS/TV1/LIN/SW/LinEmLibrary/library/Widgets/ParameterAdjustment/ScrollWheel.cpp
Indexer: processed /LinEmLibrary/library/Widgets/ParameterAdjustment/ScrollWheel.cpp [244 ms]
C/C++ Indexer: Project 'LinEmLibrary' (1 sources, 6 headers)
Options: indexer='PDOMFastIndexer', parseAllFiles=false, unusedHeaders=skip, skipReferences=false, skipImplicitReferences=false, skipTypeReferences=false, skipMacroReferences=false.
Database: 61857792 bytes
Timings: 524 total, 280 parser, 20 resolution, 25 index update.
Errors: 0 internal, 0 include, 0 scanner, 0 syntax errors.
Names: 620 declarations, 1719 references, 0(0.00%) unresolved.
Cache[1023MB]: 1571261 hits, 0(0.00%) misses.
Indexer: completed PDOMUpdateTask[524ms]
Here the indexer says it is adding and processing ScrollWheel.h and reports there are no unresolved Names.
Another important note is that the project was working fine (absolutely no issues with the Indexer) until I upgraded my system. I changed my drive from a 512G SSD to 1TB SSD. Also my project uses Log4CPlus and Google Protobuf, their headers are now installed in /usr/local/include. No change in OS (Ubuntu 20.04) or Eclipse (2021-09). The header file <log4cplus/loggingmacros.h> is no longer discovered by the indexer making all the Log4CPlus macros unresolved leaving a lot of red marks by CODAN. The auto complete is another part which seriously cripples writing code. Now every time I type in a '.' or '->' after an object the auto-complete takes a good amount of time (~30 seconds) before returning the list.
Attachment: ScrollWheel.log
(Size: 633.84KB, Downloaded 49 times) -
Attachment: .options
(Size: 0.49KB, Downloaded 79 times)
FUDForum. Page generated in 0.03543 seconds
