[SOLVED] Build Titan with FUNCTION_TEST_RUNTIME := yes [message #1844683] |
Tue, 21 September 2021 12:30 |
Emilien Bourdy Messages: 5 Registered: December 2017 |
Hi everyone,
I'm building the new version of the ETSI tests suite, and looking to the codec sources, there are some mention to the Record_Type which is not a complete type for g++.
I've found that Record_Type class is declared inside a in Basetype.hh.
I'm trying to compile Titan with FUNCTION_TEST_RUNTIME := yes in my Makefile.personal in order to have TITAN_RUNTIME_2 defined.
But when I build Titan, I have a first error concerning cversion.hh which can not be found. I copied my previous cversion.hh in the core directory (after checking that the version is the good one). After that all is build, but in linking process, I have a lot of error like:
/usr/bin/ld : libttcn3-rt2.a(Component.o):(.data.rel.ro._ZTV9COMPONENT[_ZTV9COMPONENT]+0x88) : undefind reference to "Base_Type::is_present() const"
I've also tried to make clean, copy cversion.h and make but no more success.
Is there something I'm missing? And do I need to build with FUNCTION_TEST_RUNTIME := yes in order to have the Record_Type? I really would like to not have to re-implement all the codecs...
EDIT
It was not a Titan building problem, but the project Makefil... I added the -DTITAN_RUNTIM_2 to CPPFLAGS, -R to the COMPILER_FLAGS and ttcn3-rt2-parallel to TTCN3_LIB as mention in many posts...
Sorry for the topic creation.
[Updated on: Tue, 21 September 2021 13:04] Report message to a moderator
FUDForum. Page generated in 0.03468 seconds
