Home » Eclipse Projects » Eclipse Platform » Java 17 support patch can't be installed
Java 17 support patch can't be installed [message #1844616] Fri, 17 September 2021 15:57 Go to next message
John Huss is currently offline John HussFriend
https://marketplace.eclipse.org/content/java-17-support-eclipse-2021-09-421
This item can't be installed on the latest eclipse, giving this error:
"Eclipse PDE Patch with Java 17 support for 2021-09 development stream" is not applicable to the current configuration and will not be installed.
As a result, the new pattern-matching swtich is not supported. My version is this:
Version: 2021-09 (4.21.0)
Build id: 20210910-1417
Re: Java 17 support patch can't be installed [message #1844832 is a reply to message #1844616] Mon, 27 September 2021 14:08 Go to previous message
G V is currently offline G VFriend
I also get the same error after a clean install of Eclipse 2021-09 on two Windows machines. A solution would be very much appreciated.
Previous Topic:Newer Eclipse version, older jetty version? Why?
Next Topic:Java 17 Support Patch not complete
Current Time: Sat Sep 30 18:25:12 GMT 2023
Powered by FUDForum. Page generated in 0.01833 seconds
