Re: Run Eclipse on Java 17 (latest LTS JDK) [message #1844588 is a reply to message #1844587] |
Fri, 17 September 2021 07:39 |
Alexandr Bolbat Messages: 7 Registered: September 2021 |
JDK 17 (arm64) works much faster on m1 cpu, as example i've got 65% reduced build time for one of our big projects which is ready to migrate to Java 17
Java 17 support installed in eclipse from Marketplace works fine with projects configured to use JDK 17 (arm64)
I think for now for me Eclipse still will be started with JDK 11 (x86_64) and I will migrate it to JDK 17 (arm64) when Eclipse release bundle for macOS (arm64) will be ready
[Updated on: Fri, 17 September 2021 07:41] Report message to a moderator
Re: Run Eclipse on Java 17 (latest LTS JDK) [message #1844596 is a reply to message #1844589] |
Fri, 17 September 2021 08:47 |
Lakshmi P Shanmugam Messages: 279 Registered: July 2009 Location: India |
Hi Alexandr,
The architecture types of Eclipse and the JVM should match. So, the combinations that will work on Mac M1 are:
Eclipse (x86_64) with Java (x86_64)
Eclipse (arm64) with Java (arm64)
These combinations will not work:
Eclipse (x86_64) with Java (arm64)
Eclipse (arm64) with Java (x86_64)
The Eclipse installer and IDE packages for Mac arm64 are not yet available, but the Eclipse SDK build for arm64 is available here [1]. You need the Mac OSX (64 bit version for Arm64/AArch64) download from the page and should be able to run this with Java 17 (arm64).
Please note that it's the base Eclipse SDK and you will have to install the additional plugins that are required.
[1] - https://download.eclipse.org/eclipse/downloads/drops4/R-4.21-202109060500/
HTH
Lakshmi P Shanmugam
[Updated on: Fri, 17 September 2021 08:49] Report message to a moderator
FUDForum. Page generated in 0.02757 seconds
