Label Provider not being invoked [message #1844535] |
Thu, 16 September 2021 07:06  |
I customised the label provider for my DSL, but in the outline tree I don't get the labels I customised. While debugging, my custom methods never get called.
During debugging, I noticed that when creating nodes, OutlineTreeProvicer#_text , my custom label provider is an instance of IStyledLabelProvider, so instead of invoking the methods, it calls IStyledLabelProvider#getStyledText that does not call the custom getText methods.
Is this the intended behaviour? How can I get the styled label provider to use the custom getText methods? I see doGetText called, but not the getText ones.
Horacio Hoyos Rodriguez
Kinori Tech
Need professional support for Epsilon, EMF?
Go to: https://kinori.tech
Re: Label Provider not being invoked [message #1844543 is a reply to message #1844537] |
Thu, 16 September 2021 10:51   |
Thanks for the reply.
There is no exception, just the labels I defined not being used.
The org.eclipse.xtext.ui.editor.outline.impl.DefaultOutlineTreeProvider._text(Object) is the method I am looking at.
Is there some additional binding I need to do in the UI Module or else where? I think what I am missing is the part that does the dynamic dispatch to the specific text(XXX ele) for the ele's class.
Kinori Tech
Re: Label Provider not being invoked [message #1844548 is a reply to message #1844544] |
Thu, 16 September 2021 12:01   |
_text(Object) is called.
What is not working is that that method does not in turn call the String text(<Rule> ele) methods (I understood you gave to implement the text(<Rule> ele) method for each node that you want to customise)
Kinori Tech
Re: Label Provider not being invoked [message #1844550 is a reply to message #1844548] |
Thu, 16 September 2021 13:13   |
of course it does not as it calls
MyDslLabelProvider.text(Greeting) line: 27
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 62
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 43
Method.invoke(Object, Object...) line: 566
PolymorphicDispatcher<RT>.invoke(Object...) line: 303
MyDslLabelProvider(DeclarativeLabelProvider).doGetText(Object) line: 52
MyDslLabelProvider(DefaultEObjectLabelProvider).doGetText(Object) line: 36
MyDslLabelProvider(AbstractLabelProvider).getStyledText(Object) line: 122
MyDslOutlineTreeProvider(DefaultOutlineTreeProvider)._text(Object) line: 276
why does the reflection in doGetText not work for you?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Label Provider not being invoked [message #1844562 is a reply to message #1844550] |
Thu, 16 September 2021 14:43   |
That is what I am trying to figure out! hehe.
never gets called.
The line called in MyDslLabelProvider is line 72, Object text(Object element), so its like the runtime dispatch is not working for some reason
Kinori Tech
Re: Label Provider not being invoked [message #1844585 is a reply to message #1844563] |
Fri, 17 September 2021 06:43  |
It somehow resolved it self. I think it was linked to an imported metamodel not being found at runtime (i.e. EPackage not registered exception). Perhaps the label provider logic catches the exception and just returns null.
Kinori Tech
FUDForum. Page generated in 0.02416 seconds
