Home » Modeling » TMF (Xtext) » Validator(Validator to avoid repetition)
Validator [message #1844281] Wed, 08 September 2021 01:31 Go to next message
Muhammad Salman Tayyab is currently offline Muhammad Salman TayyabFriend
Member
Hi, I am writing a validator to avoid repetition.
Variable names should be unique.
In the grammar screenshot (attached below), the "videos" variable should always be unique.
In the other screenshot, I tried to write the custom validation rule for it. Please see the validation file screenshot and guide me, what I have to do. I am new to Xtext and confused about how to write the correct code for it. Thank you.
Salman
Re: Validator [message #1844282 is a reply to message #1844281] Wed, 08 September 2021 05:06 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
the snippet you posted non proper java code in a java files.
you have to write the check in pure java then.
e.g.
video.getVideos()
and have a proper java map (or set) decl
e.g. Set<String> existing = new HashSet<>();
if (existing.add(v.getName())) {
error(.....);
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Wed, 08 September 2021 05:52]
Report message to a moderator
Re: Validator [message #1844297 is a reply to message #1844282] Wed, 08 September 2021 11:24 Go to previous messageGo to next message
Member
Do you mean that I have to write this repetition check in the dslgenerator.xtend file?
Below I have modified the validation file. Please have a look and guide me because I am confused in this.
@Check
public void checkDuplicateVarName(Video video) {
///var map = new HashMap <String, Video >
for(Videodef v: video.getVideos()) {
if(!existing.add(v.getName())) {
error("Variable Name should be unique",
VideoDslPackage.Literals.VIDEO__VIDEOS,
DUPLICATE_VAR);
Salman
[Updated on: Wed, 08 September 2021 11:37]
Re: Validator [message #1844302 is a reply to message #1844297] Wed, 08 September 2021 13:28 Go to previous messageGo to next message
Member
@Check
DUPLICATE_VAR);
Hello, From the above code, error always appears on the first line.
How can I add the error message to the line on which we are writing the duplicate variable?
Salman
[Updated on: Wed, 08 September 2021 13:29]
Re: Validator [message #1844316 is a reply to message #1844302] Wed, 08 September 2021 18:02 Go to previous message
You can call the overloads of
Error that also take an eobject and estructuralfesture
You can pass v as eobject
And YouOackage.literals.videodef_name as feature
Previous Topic:Cannot Reference One Xcore Model from Another
Next Topic:No Xtext languages have been registered
Current Time: Tue Mar 28 18:48:06 GMT 2023
Powered by FUDForum. Page generated in 0.02120 seconds
