Home » Eclipse Projects » Sirius » [Sirius Web] Rectalinear edges
[Sirius Web] Rectalinear edges [message #1843599] Tue, 10 August 2021 11:18 Go to next message
Denis Nikiforov is currently offline Denis NikiforovFriend
Does Sirius Web support rectalinear edges? I created a Robot Flow sample model. Initially edges are rectalinear. But when I drag a node, edges become diagonal.
Re: [Sirius Web] Rectalinear edges [message #1843812 is a reply to message #1843599] Thu, 19 August 2021 12:29 Go to previous message
Pierre-Charles David is currently offline Pierre-Charles DavidFriend
Hi.
This is a known limitation. We've recentely improved the situation (see https://github.com/eclipse-sirius/sirius-components/issues/550) but there are still known issues in this area.
Basically, the global automatic layout (which is performed on the backend using ELK) produces rectilinear edges, but when you manually move elements the incremental change does not trigger the same algorithms. The one we use at the moment does not currently support edges routing, so it resets them to a single straight line.
Pierre-Charles David - Obeo
Previous Topic:[Sirius Web] Model Explorer customization
Next Topic:Sirus Web Creating elements programmatically
Current Time: Sun Nov 27 19:36:05 GMT 2022
Powered by FUDForum. Page generated in 0.02402 seconds
