Enable Graphical EMF Compare of Model [message #1843330] |
Fri, 23 July 2021 15:18 |
Brandon Lewis Messages: 268 Registered: May 2012 |
I can't seem to figure out where to start here. Both Sirius and EMF Compare share examples of graphical diffs in their documentation and the examples sure do look like Sirius editors - even down to the Family model used in the tutorials.
EMF Compare gives good examples of how to setup a compare either in standalone or in the IDE, but it always involves calling the compare on your own somehow.
Is there a deceptively easy way that this is enabled for any given Ecore model?
I have a bunch of diagrams, but I can't figure out step 1 for telling Sirius:
1) how to graphically compare my diagrams
2) how to invoke such a comparison - i.e. what element would I Right Click -> Team -> Compare on to invoke these graphical diffs I see on the advertised websites?
Is there some extension point I have to use?
[Updated on: Fri, 23 July 2021 15:20] Report message to a moderator
Re: Enable Graphical EMF Compare of Model [message #1843371 is a reply to message #1843330] |
Mon, 26 July 2021 16:18 |
Glenn Plouhinec Messages: 22 Registered: April 2020 |
Hi Brandon,
In order to use the diagram comparison with EMF Compare, the EMF Compare Sirius integration must be installed from the update site. It may be necessary to add the extension of a model in the preferences pages (General > Content Types, then select EMF Compare and add your extension to the "File associations" section). Add the extensions '*.ecore' and '*.aird'.
To compare two models, you can select your two files '*.aird' or '*.ecore' and right click > Compare With > ..., or select a single file and compare with another version of the file (local history, commit, ...).
Glenn
Glenn Plouhinec - Obeo
FUDForum. Page generated in 0.02881 seconds
