Home » Eclipse Projects » Memory Analyzer » Inspect objects from comparison(For example, suppose +100 java.lang.String found, be able to see those specific strings)
Inspect objects from comparison [message #1843233] Tue, 20 July 2021 22:40 Go to next message
Hi all,
When I compare two heap dumps, I can see the +/- counts of object instances. I cannot however seem to find a way to review the values of those instances.
For example, suppose I see +10 instances of java.lang.String between heap dumps A and B. How can I view the 10 strings that are different between the two copies? That would be quite useful in determining the origin.
Is this possible using the tool?
Re: Inspect objects from comparison [message #1843273 is a reply to message #1843233] Thu, 22 July 2021 10:43 Go to previous message
I would suggest running group_by_value java.lang.String on both dumps, add each result to the compare basket, run the compare query, select 'difference from the base table' from the tool bar, then use '<>0' in the filter for column 'Objects #2-#1'
Previous Topic:HTML Report
Next Topic:Issues with MAT reading AdoptJDK openj9 core.dmp files
Current Time: Sat Feb 08 20:23:29 GMT 2025
Powered by FUDForum. Page generated in 0.02973 seconds
