Home » Modeling » TMF (Xtext) » Performance issue when doing index of resourceset
Performance issue when doing index of resourceset [message #1843126] Fri, 16 July 2021 10:28 Go to next message
Juewei Jin is currently offline Juewei JinFriend
I'm facing a performance issue with a single DSL file. We have added a second DSL, one of this DSL file contains around 3300 lines.
Example with reduced content:
DQRules-configuration test {
	generateDqRulesOnlyForTargetEntites
	DqRules-Id-Mapping {
		DqRules-Id-Mapping-From-Legacy-Slf {
			"MONITOR.xxx.001" --> "MONITOR.yyy.001"
			"MONITOR.xxx.002" --> "MONITOR.yyy.002"
		DqRules-Id-Mapping-New{
	DQRules-Deactivation-Data_Exists {
	DQRules-Deactivation-Validity{
	DQRules-Deactivation-Null_Check {
        "model.abc.test1"
        "model.abc.test2"
	DQRules-Deactivation-Uniqueness {
	DQRules-Deactivation-Ref_Integrity {
        "model.cde.test1"
        "model.cde.test2"
The DSL grammar for this file see below.
Now we are facing the performance issue when we doing the indexing (see the code below) with this new DSL file. It took now much more time to do it. Even the lines in this file were commented out, no change with the performance. Only when the content of this file be reduced, then the indexing performance get improved.
But we don't have issue with the file of another DSL, which also contains a lot of lines.
Is this performance because of bad grammar design? Or what else can be the reason?
List<IResourceDescription> descriptions = newArrayList();
		for (Resource resource : resourceSet.getResources()) {
			IResourceServiceProvider serviceProvider = serviceRegistry.getResourceServiceProvider(resource.getURI());
			IResourceDescription description = serviceProvider.getResourceDescriptionManager()
					.getResourceDescription(resource);
			descriptions.add(description);
		index = new ResourceDescriptionsData(descriptions);
		EcoreUtil.resolvAll(resourceSet)
 ResourceDescriptionsData.ResourceSetAdapter.installResourceDescriptionsData(resourceSet, index);
class ConfigurationDqRules extends Configuration {
	Boolean generateDqRulesOnlyForTargetEntites
	contains DqRulesIdMappingList dqRulesIdMappingList
	contains DataExistsDqRuleDeactivation dataExistsDqRuleDeactivation
	contains ValidityDqRuleDeactivation validityDqRuleDeactivation
	contains NullCheckDqRuleDeactivation nullCheckDqRuleDeactivation
	contains UniquenessDqRuleDeactivation uniquenessDqRuleDeactivation
	contains RefIntegrityDqRuleDeactivation refIntegrityDqRuleDeactivation
class DqRulesIdMappingList {
	contains DqRulesIdMappingFromLegacySlf dqRulesIdMappingFromLegacySlf
	contains DqRulesIdMappingNew dqRulesIdMappingNew
class DqRulesIdMappingFromLegacySlf {
	contains DqRulesIdMapping [] dqRulesIdMapping
class DqRulesIdMappingNew {
class DqRulesIdMapping {
	String dqRuleId
	String mapTo
class DataExistsDqRuleDeactivation {
	contains  DataExistsDqRule [] dataExistsDqRule
class DataExistsDqRule {
	String entity
class ValidityDqRuleDeactivation{
	contains ValidityDqRule [] ValidityDqRule
class ValidityDqRule {
	String entityProperty
class NullCheckDqRuleDeactivation {
	contains NullCheckDqRule [] nullCheckDqRule
class NullCheckDqRule {
class UniquenessDqRuleDeactivation {
	contains UniquenessDqRule [] uniquenessDqRule
class UniquenessDqRule {
	String entity
[Updated on: Fri, 16 July 2021 11:02]
Report message to a moderator
Re: Performance issue when doing index of resourceset [message #1843127 is a reply to message #1843126] Fri, 16 July 2021 10:30 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hi, i recommend you to profile and share the results.
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Performance issue when doing index of resourceset [message #1843131 is a reply to message #1843127] Fri, 16 July 2021 11:04 Go to previous messageGo to next message
hi Christian,
thanks for the quick reply.
What do you mean exactly use the profile and share the result?
Re: Performance issue when doing index of resourceset [message #1843132 is a reply to message #1843131] Fri, 16 July 2021 11:13 Go to previous messageGo to next message
Here is the performance compare: we have around 5000 files of DSL1 + 1 file of DSL2 (which cause the performance issue)
Situation 1: DSL2 file with less than 50 lines, finish indexing with all files took 71445ms
Situation 2: DSL2 file with 3300 lines, finish indexing with all files took 265773ms
Situation 3: DSL2 file with 3300 lines but comment out 3250 lines, finish indexing with all files took 161888ms
and main part of the code for the standalone mode look like below
		logger.info('''init model''')
		val modelInjector = new StandaloneModelStandaloneSetup().createInjectorAndDoEMFRegistration()
		logger.info('''done.''')
		logger.info('''init conf''')
		new ConfigurationStandaloneSetup().createInjectorAndDoEMFRegistration
		val standalone = modelInjector.getInstance(StandaloneExecutor)
		logger.info('''run standalone''')
		logger.info('''load model resources into resource set''')
		val modelFolder = new File(URI.createURI(mainArgs.modelDir + "/model").toFileString)
		logger.info('''model folder: «modelFolder»''')
		val modelEnvironment = (modelInjector.getProvider(IEnvironment).get as AbstractEnvironment)
		modelEnvironment.setProjectLocation(mainArgs.modelDir)
		val resourceSet = new ResourceSetImpl()
		resourceSet.loadOptions.put(XtextResource.OPTION_ENCODING, StandardCharsets.UTF_8.name());
		val modelFileSystemAccess = modelInjector.getInstance(JavaIoFileSystemAccess)
		modelFileSystemAccess.setOutputPath(URI.createURI(mainArgs.outputDir).toFileString)
		val modelFiles = FileUtils.listFiles(modelFolder, new ArrayList<String> => [add("model"); add("conf");], true)
		logger.info('''[loading] «modelFiles.length» files ...''')
		var returnCode = -1
		try {
			val standaloneResourceAdapter = new StandaloneResourceAdapter
			for (f : modelFiles) {
				val uri = URI.createFileURI(f.absolutePath)
				logger.debug("[load] " + uri.toString)
				val resource = resourceSet.getResource(uri, true)
				resource.eAdapters.add(standaloneResourceAdapter)
			resourceSet.eAdapters.add(standaloneResourceAdapter)
			returnCode = standalone.doGenerate(mainArgs, modelInjector, resourceSet, CompilationMode.SINGLE_AND_BATCH)
		} catch (Exception e) {
			logger.error("message: " + e.message)
			logger.error("stacktrace: " + e.stackTrace.toString)
[Updated on: Fri, 16 July 2021 11:16]
Re: Performance issue when doing index of resourceset [message #1843134 is a reply to message #1843132] Fri, 16 July 2021 11:38 Go to previous messageGo to next message
I don't understand the semantics of "contains" in your DSL, but ...
It looks as if your model may be very flat and so you may violate the EMF expectation that your model is a tree. EMF does linear search at each level which is fine for the siblings in a typical tree but can be disastrous for a large flat file if any algorithm is quadratic.
Ed Willink
Re: Performance issue when doing index of resourceset [message #1843135 is a reply to message #1843134] Fri, 16 July 2021 11:53 Go to previous messageGo to next message
i mean yourkit, jvisualvm etc.
they will show you where cpu times is spent
Re: Performance issue when doing index of resourceset [message #1843136 is a reply to message #1843134] Fri, 16 July 2021 11:59 Go to previous messageGo to next message
Hi Ed,
we use xcore to define the meta model. "contains" is the keyword in xcore.
Another interesting thing is, we execute the xtext generator both in Eclipse IDE mode and Standalone mode. With the same DSL files, the execution time in Eclipse IDE is much more faster than the standalone mode.
The only different part in the code is in standalone mode we createInjectorAndDoEMFRegistration and load the resources to resourceset explicitly in the code. Then both modes use the same indexing code. I don't know what happen behind the Eclipse IDE mode. But it seams that the Eclipse IDE mode can treat the DSL elements more effcient.
		var returnCode = -1
		try {
			// the indexing happened in the doGenerate method
Re: Performance issue when doing index of resourceset [message #1843137 is a reply to message #1843136] Fri, 16 July 2021 12:05 Go to previous messageGo to next message
please measure. and maybe you can provide a complete reproducible hello world example
Re: Performance issue when doing index of resourceset [message #1843138 is a reply to message #1843137] Fri, 16 July 2021 12:06 Go to previous messageGo to next message
btw this call order seems wrong
if you install index after resolving,
then resolving wont profit from indexing
Re: Performance issue when doing index of resourceset [message #1843141 is a reply to message #1843138] Fri, 16 July 2021 12:36 Go to previous messageGo to next message
hi Christian,
sorry, that was my copy paste error, the resolveAll is after the indexing in the code.
Re: Performance issue when doing index of resourceset [message #1843323 is a reply to message #1843141] Fri, 23 July 2021 13:25 Go to previous messageGo to next message
I tried to process two DSL model files separately. and even not load the DSL2 model and not get index of DSL2 model (see the codes are commented out). The indexing execution time has no change still very long. How can this happen? I tried several times, only difference is the size of DSL2 model file.
I'm not familiar with EMF. If I am wrong, please correct me. So following is my guess:
when we call "createInjectorAndDoEMFRegistration()", all DSL1 and DSL2 models are parsed into Antlr trees (or xtext nodemodel) in memory. And then even the DSL2 files are not loaded to the XtextResourceSet. The Antlr tree still contains the big DSL2 part. It slows down to create index for DSL1 models.
		val configurationInjector = new ConfigurationStandaloneSetup().createInjectorAndDoEMFRegistration
		logger.info('''init GitManager''')
		val gitManager = modelInjector.getInstance(GitManager) as StandaloneGitManager
		gitManager.userName = mainArgs.gitUserName
		gitManager.password = mainArgs.gitPassword
//		val configurationEnvironment = (configurationInjector.getProvider(IEnvironment).get as AbstractEnvironment)
//		configurationEnvironment.setProjectLocation(mainArgs.modelDir)
//		val resourceSet = new ResourceSetImpl()
		val modelResourceset = modelInjector.getInstance(XtextResourceSet)
		modelResourceset.loadOptions.put(XtextResource.OPTION_ENCODING, StandardCharsets.UTF_8.name());
		val configurationResourceset = configurationInjector.getInstance(XtextResourceSet)
		configurationResourceset.loadOptions.put(XtextResource.OPTION_ENCODING, StandardCharsets.UTF_8.name());
		val configurationFileSystemAccess = configurationInjector.getInstance(JavaIoFileSystemAccess)
		configurationFileSystemAccess.setOutputPath(URI.createURI(mainArgs.outputDir).toFileString)
		val modelFiles = FileUtils.listFiles(modelFolder, new ArrayList<String> => [add("model");], true)
		val configurationFiles = FileUtils.listFiles(modelFolder, new ArrayList<String> => [add("conf");], true)
		logger.info('''[loading] «modelFiles.length + configurationFiles.length» files ...''')
		var returnCode = -1
		try {
				val resource = modelResourceset.getResource(uri, true)
			modelResourceset.eAdapters.add(standaloneResourceAdapter)
//			for (f : configurationFiles) {
//				val uri = URI.createFileURI(f.absolutePath)
//				logger.debug("[load] " + uri.toString)
//				val resource = configurationResourceset.getResource(uri, true)
//				resource.eAdapters.add(standaloneResourceAdapter)
//			configurationResourceset.eAdapters.add(standaloneResourceAdapter)
			returnCode = standalone.doGenerate(mainArgs, modelInjector, modelResourceset, configurationResourceset, CompilationMode.SINGLE_AND_BATCH)
protected void doGenerate(......) {
		doIndex();
	protected void doIndex() {
			long startTimeIndexing = System.nanoTime();
			logger.info("[indexing]");
			// indexing
			List<IResourceDescription> modelDescriptions = newArrayList();
			List<IResourceDescription> configurationDescriptions = newArrayList();
			for (Resource resource : modelResourceSet.getResources()) {
				modelDescriptions.add(description);
			modelIndex = new ResourceDescriptionsData(modelDescriptions);
//			for (Resource resource : configurationResourceSet.getResources()) {
//				IResourceServiceProvider serviceProvider = serviceRegistry.getResourceServiceProvider(resource.getURI());
//				IResourceDescription description = serviceProvider.getResourceDescriptionManager()
//						.getResourceDescription(resource);
//				configurationDescriptions.add(description);
//			configurationIndex = new ResourceDescriptionsData(configurationDescriptions);
			ResourceDescriptionsData.ResourceSetAdapter.installResourceDescriptionsData(modelResourceSet, modelIndex);
			ResourceDescriptionsData.ResourceSetAdapter.installResourceDescriptionsData(configurationResourceSet,
					configurationIndex);
			long endTime = System.nanoTime();
			long durationNanoSecond = (endTime - startTimeIndexing);
			logger.info("[indexing] finished in " + durationNanoSecond / 1000000 + "ms.");
Re: Performance issue when doing index of resourceset [message #1843324 is a reply to message #1843323] Fri, 23 July 2021 13:26 Go to previous message
again. please provide a yourkit or similar measurement or a complete example
Previous Topic:Deadlock between Job and event listener on Display thread
Next Topic:Umsetzung von Xtend-Funktionen basierend auf einem UML-Klassendiagramm
Current Time: Tue May 24 09:27:41 GMT 2022
Powered by FUDForum. Page generated in 0.02488 seconds
