I just installed Eclipse yesterday and can't figure this out. I'm using Python in Eclipse and have this simple program, which should log stuff to the console:
test_int = 0
for i in range(0, 10000):
test_int += 1
print(str(test_int))
y = input("WTF?")
Which works fine. The problem is when I try to import Selenium and change the code to this
from selenium import webdriver
test_int = 0
test_int += 1
y = input("WTF?")
Now when I run the same program, the console in Eclipse won't display the input until I click somewhere in the coding window after the program has started running. Then the console updates instantly.
I've attached a screenshot after the program has been running 10 seconds, and you can see the console hasnt updated. The second screenshot is after I click on the coding window, and the console updates.
Thanks for your help in fixing this.
