Home » Eclipse Projects » Remote Application Platform (RAP) » How to access the request parameters?(request parameter)
How to access the request parameters? [message #1843005] Sat, 10 July 2021 12:12 Go to next message
Hello
I would like to use the request parameters from the RAP FAQ (https://wiki.eclipse.org/RAP/FAQ#How_to_access_the_request_parameters.3F )
When it is called directly from the browser, it performs normal.
However, calling Curl, HTTP Client, or RestClient does not produce results. What should I do?
Please help me.
Test code
try {
			HttpClient httpclient = HttpClients.createDefault();
			HttpPost httpget = new HttpPost("http://127.0.0.1:8080/main/?testUID=402baba0-2683-49fc-9881-5e038972d48a&&method=PreferenceInitialize");
			httpget.setHeader("Accept", "application/json");
			httpget.setHeader("Content-type", "application/json");
			httpget.setHeader("Cache-Control", "no-cache");
			httpget.setHeader("Content-type", "no-store");
			httpget.setHeader("Content-type", "private");
			httpget.setHeader("Pragma", "no-chache");
			// Request parameters and other properties.
			List<NameValuePair> params = new ArrayList<NameValuePair>(2);
			params.add(new BasicNameValuePair("testUID", "402baba0-2683-49fc-9881-5e038972d48a"));
			params.add(new BasicNameValuePair("method", "PreferenceInitialize"));
			httpget.setEntity(new UrlEncodedFormEntity(params, "UTF-8"));
			//Execute and get the response.
			HttpResponse response = httpclient.execute(httpget);
			HttpEntity entity = response.getEntity();
			if (entity != null) {
			  InputStream instream = entity.getContent();
			  try {
			    // do something useful
			  } finally {
			    instream.close();
		 } catch(Exception e) {
			 e.printStackTrace();
[Updated on: Sat, 10 July 2021 12:16] by Moderator
Re: How to access the request parameters? [message #1843057 is a reply to message #1843005] Tue, 13 July 2021 12:50 Go to previous messageGo to next message
help me~
Re: How to access the request parameters? [message #1843091 is a reply to message #1843057] Thu, 15 July 2021 04:11 Go to previous messageGo to next message
Hello Cho,
I think it is not possible to access parameters that way when calling the application via a REST client or similar. As far as I understand, passing these startup parameters to the application' entry point is done in Javascript when the client side rwt.widgets.Display is initialized. The display is not created when using REST clients.
Maybe you can use a servlet filter [1]; a filter will receive the passed parameters from a REST client.
Sebastian
[1] https://docs.oracle.com/cd/B14099_19/web.1012/b14017/filters.htm
Re: How to access the request parameters? [message #1843111 is a reply to message #1843091] Fri, 16 July 2021 00:19 Go to previous messageGo to next message
Thanks @Sebastian HabenichtFriend
Any other anseers?
Re: How to access the request parameters? [message #1843258 is a reply to message #1843111] Wed, 21 July 2021 11:41 Go to previous messageGo to next message
RAP provides org.eclipse.rap.rwt.client.service.StartupParameters client service.
Ivan
Re: How to access the request parameters? [message #1843259 is a reply to message #1843258] Wed, 21 July 2021 11:52 Go to previous message
Hi.
I know StartupParameters client service. I'm using it well.
My question is, for example
1. Server is http://localhost:10082
2. Calling http://localhost:10082/?param=value in the chrome address bar works fine.
But, calling http://localhost:10082/?param=value with CURL or HttpClient, it is not called.
I don't know what the difference is.
I want to call parameters with HttpClient.(Same thins RestClient tool)
Thanks.
Previous Topic:How to deploy RAP. Is there an up to date description available
Next Topic:Property to make ServiceManager.getServiceHandlerUrl() return relative URLs
Current Time: Sun Mar 16 16:37:17 EDT 2025
Powered by FUDForum. Page generated in 0.05817 seconds
