Home » Newcomers » Newcomers » Dependency injection with @inject(Dependency injection with @inject having problems)
| Dependency injection with @inject [message #1842866] |
Sat, 03 July 2021 23:20  |
I currently have a pagination class, I will share it here:
package net;
public class PageClass {
String pagination;
public void setpagination(int maxPage, int cpage, String vfile, String queryvars, String pageName) {
String pag = "<div class='pagination'>";
int fpage = 1;
int page = cpage;
int limit = 3;
int pageno = cpage;
int spage = cpage;
int lower = spage - 1;
int upper = spage + 1;
String self = vfile + "?";
int khigh = 0;
int klow = 0;
if (maxPage > limit) {
if (pageno > 1) {
pag = pag + "<li><a href=" + self + pageName + "=" + fpage + queryvars + ">1..</a></li>";
pag = pag + "<li><a href=" + self + pageName + "=" + (pageno - 1) + queryvars + ">« </a></li>";
if (spage == 1) {
klow = spage;
khigh = limit;
if (spage > 1) {
if (lower < 1) {
klow = 1;
khigh = limit;
} else {
klow = lower;
khigh = upper;
if (upper > maxPage) {
khigh = maxPage;
klow = maxPage - (2 * 1);
for (int i = klow; i <= khigh; i++) {
if (i == pageno) {
pag = pag + "<li><span class='active'>" + i + "</span></li>";
} else {
pag = pag + "<li><a href=" + self + pageName + "=" + i + queryvars + ">" + i + "</a></li>";
//pag = pag + "<li><a href=" + self + this->pag->pageName + "=" + i + queryvars + ">" + i + "</a></li>" + "\n";
if (pageno < maxPage) {
//pag = pag + "<span>...</span>";
pag = pag + "<li><a href='" + self + pageName + "=" + (pageno + 1) + queryvars + "'>" + " »</a></li>";
pag = pag + "<li><a href='" + self + pageName + "=" + (maxPage) + queryvars + "'>" + " .." + maxPage + "</a></li>";
} else {
/* * * if this is page 1 there is no previous link ** */
if (pageno != 1) {
pag = pag + "<li><a href='" + self + pageName + "=" + (pageno - 1) + queryvars + "'>« </a></li>";
/* * * loop over the pages ** */
for (int i = 1; i <= maxPage; i++) {
if (i == pageno) {
pag = pag + "<li><span class='active'>" + i + "</span></li>" + "";
} else {
pag = pag + "<li><a href='" + self + pageName + "=" + i + queryvars + "'>" + i + " " + "</a></li>";
} //pag = pag + "<li><a href='" + self + pageName + "=" + i + queryvars + "'>" + i + " " + "</a></li>" + "\n";
/* * * if we are on the last page, we do not need the NEXT link ** */
pag = pag + "<li><a href='" + self + pageName + "=" + (pageno + 1) + queryvars + "'> » </a></li>";
pag = pag + "<li><a href='" + self + pageName + "=" + maxPage + queryvars + "'> last </a></li>";
pag = pag + "</div>";
//String tmppag;
if (maxPage < 2) {
pag = "";
this.pagination = pag;
public String getpagination() {
return (this.pagination);
It works great, but I have to load class like this:
net.PageClass paging = new net.PageClass();
I am trying to use @inject, I have placed all required things in servlet:
import jakarta.enterprise.context.RequestScoped;
import jakarta.inject.Inject;
and
@MultipartConfig
@WebServlet(
name = "FindOwnerServlet",
urlPatterns = {"/FindOwnerServlet"}
@RequestScoped
public class FindOwnerServlet extends HttpServlet {
@Inject net.PageClass paging;
Usage is as follows:
String vfile = "FindOwnerServlet";
String queryvars = "&t1=" + t1;
String pagename = "page";
paging.setpagination(cPage, pageno, vfile, queryvars, pagename);
String pagination = paging.getpagination();
Again, all works, but I cannot use @inject, it only works using the "new" keyword.
How can I get the @inject to work?
It's a jakarta 9 web project.
| Re: Dependency injection with @inject [message #1842871 is a reply to message #1842867] |
Sun, 04 July 2021 13:33   |
Stephane Thanks for reply. I did all you said, but still not working. No error, but blank pagination. It's as though @inject expects parameters, however I don't pass parameters til later in the servlet like:
paging.setpagination(cPage, pageno, vfile, queryvars, pagename); // then
So I need an instance of the class, but actual usage comes later in the servlet. As said I am loading class like:
However I would like to use the more modern @inject. I even tried moving at inject just before usage. Does @inject not work for a class that has to pass parameters later? Thanks
Edit:
I did a singleton, it works also:
package net;
public class PGClass {
private static final PGClass instance
= new PGClass();
String pagination;
private PGClass() {
public static PGClass getInstance() {
return instance;
public String getpagination(int maxPage, int cpage, String vfile, String queryvars, String pageName) {
etc, same code from first pagination class
And usage:
String pagination = net.PGClass.getInstance().getpagination(cPage, pageno, vfile, queryvars, pagename);
Do you think such a class is okay in this use case? I would still like @inject to work however. But I tried for hours with no luck.
[Updated on: Sun, 04 July 2021 14:56] by Moderator
| Re: Dependency injection with @inject [message #1842873 is a reply to message #1842872] |
Sun, 04 July 2021 16:22   |
Nitin the the update just has the new name PGClass:
package net;
= new PGClass();
String pagination;
private PGClass() {
return instance;
int fpage = 1;
int page = cpage;
int limit = 3;
int pageno = cpage;
int spage = cpage;
int khigh = 0;
int klow = 0;
if (pageno > 1) {
if (spage == 1) {
klow = spage;
khigh = limit;
if (spage > 1) {
if (lower < 1) {
klow = 1;
khigh = limit;
} else {
klow = lower;
khigh = upper;
khigh = maxPage;
if (i == pageno) {
} else {
} else {
if (pageno != 1) {
if (i == pageno) {
} else {
//String tmppag;
if (maxPage < 2) {
pag = "";
Usage in the servlet:
And passed to jsp view:
request.setAttribute("mypager", pagination);
// other request
RequestDispatcher dispatcher = request.getRequestDispatcher(displaypage);
And in jsp page:
Also I am still tweaking as needed but it works. I just cannot figure out how to use @inject with the pagination.
[Updated on: Sun, 04 July 2021 16:31] by Moderator
| Re: Dependency injection with @inject [message #1842880 is a reply to message #1842879] |
Sun, 04 July 2021 22:33   |
Nitin I did try that: I changed name to PagingClass. And I added a blank bean.xml.
package net;
@RequestScoped
public class PagingClass {
private static final PagingClass instance
= new PagingClass();
String pagination;
private PagingClass() {
public static PagingClass getInstance() {
return instance;
int fpage = 1;
int page = cpage;
int limit = 3;
int pageno = cpage;
int spage = cpage;
int khigh = 0;
int klow = 0;
if (pageno > 1) {
if (spage == 1) {
klow = spage;
khigh = limit;
if (spage > 1) {
if (lower < 1) {
klow = 1;
khigh = limit;
} else {
klow = lower;
khigh = upper;
khigh = maxPage;
if (i == pageno) {
} else {
} else {
if (pageno != 1) {
if (i == pageno) {
} else {
//String tmppag;
if (maxPage < 2) {
pag = "";
And top of servlet:
package net;
import jakarta.servlet.*;
import java.sql.*;
import java.util.ArrayList;
import SQLBean.ConnBean;
import java.io.IOException;
import java.io.PrintWriter;
import java.util.List;
import jakarta.servlet.ServletException;
import jakarta.servlet.annotation.MultipartConfig;
import jakarta.servlet.annotation.WebServlet;
import jakarta.servlet.http.HttpServlet;
import jakarta.servlet.http.HttpServletRequest;
import jakarta.servlet.http.HttpServletResponse;
* @author jimwin7a
@MultipartConfig
@WebServlet(
@Inject net.PagingClass mypager;
And tried to use like:
String pagination = mypager.getpagination(cPage, pageno, vfile, queryvars, pagename);
However without @inject, this does work:
net.PagingClass mypager = net.PagingClass.getInstance();
I tried everything with original getter setter class and the new singleton class, but for now am using the singleton. I just can't seem to get @inject to work.
I even tried @EJB I saw in an S.O. post. I even took out the returning of the instance. So far only thing working is:
[Updated on: Sun, 04 July 2021 23:05] by Moderator
| Re: Dependency injection with @inject [message #1842906 is a reply to message #1842897] |
Tue, 06 July 2021 00:25   |
Thank you so much, all who helped. That Apache TomEE 9.0.0-M7-webprofile did the trick, also is the super part needed, I added it. But all works now.
I had TomEE up and running in minutes, new project, copied web pages and beans and servlets over, assigned TomEE, added the super, clean and build, worked.
For TomEE in netbeans to work I had to uncheck "Use IDE Proxy Settings" under the Platform tab. However with Tomcat 10 I didn't have to, any ideas why?
But happy all is good, I now know why inject wasn't working.
Stephane I basically just changed my original code as needed to match your example, and added the super.
[Updated on: Tue, 06 July 2021 00:37] by Moderator
Current Time: Sun Nov 02 05:04:52 EST 2025
Powered by FUDForum. Page generated in 0.12211 seconds
