Home » Modeling » TMF (Xtext) » Cannot find compatible feature name(Xtext setup after migrating to Xtext 2.15)
Cannot find compatible feature name [message #1842781] Thu, 01 July 2021 06:38 Go to next message
I migrated down from Xtext 2.25 to 2.15, because I had some depency issues.
Now, my grammar throws the error:
Cannot find compatible feature name in sealed EClass JavaStatement
from imported package http://www.example.org/cbcmodel: The type
'XExpression' used in the reference 'name' is inconsistent.
Probably this is due to an unsupported kind of metamodel hierarchy.
Here is my rule:
JavaStatement returns JavaStatement:
	(name+=XExpression)+;
and my ecore for that piece:
<eClassifiers xsi:type="ecore:EClass" name="JavaStatement">
    <eStructuralFeatures xsi:type="ecore:EReference" name="name" upperBound="-1" eType="ecore:EClass ../../org.eclipse.xtext.xbase/model/Xbase.ecore#//XExpression"
        containment="true"/>
The code worked in Xtext 2.25.
Re: Cannot find compatible feature name [message #1842783 is a reply to message #1842781] Thu, 01 July 2021 06:58 Go to previous messageGo to next message
maybe its better to have a namespace uri the or a platform:/resource/org.eclipse.xtext.xbase/model/Xbase.ecore#//XExpression
Re: Cannot find compatible feature name [message #1842786 is a reply to message #1842783] Thu, 01 July 2021 07:33 Go to previous messageGo to next message
I tried to use the platform url you provided.
This doesn't solve the problem.
Using "ecore:EClass http://www.eclipse.org/xtext/xbase/Xbase#//XExpression" as eType did thrown an error the package ... has the same namespace URI ...
I also tried importing the uri in the .xtext file:
import "http://www.eclipse.org/xtext/xbase/Xbase"
This didn't do anything either.
Re: Cannot find compatible feature name [message #1842801 is a reply to message #1842786] Thu, 01 July 2021 12:37 Go to previous messageGo to next message
Moving from 2.25 to 2.15 is a long way. Have you changed everything consistently? Java compatibility has changed significantly in that time.
You only provide snippets that make it almost impossible to divine what you are really doing.
Comparing my grammars with their four-year old counterparts, I find very little structural change. However I have obstinately refused to move on from manual metamodels referenced as
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
import "platform:/resource/org.eclipse.ocl.pivot/model/Pivot.ecore" as pivot
despite Xtext tooling encouragement to change. Your comment suggests you may not be using platform:/resource for cbcmodel.
Ed Willink
Re: Cannot find compatible feature name [message #1842806 is a reply to message #1842801] Thu, 01 July 2021 14:32 Go to previous messageGo to next message
Maybe you can debug where
The Xbase.ecore is loaded twice from different resources
Besides that can you provide a reproducer
Re: Cannot find compatible feature name [message #1842807 is a reply to message #1842806] Thu, 01 July 2021 14:35 Go to previous messageGo to next message
BTW what is the reason you want to downport to 2.15
There was some bugs fixed since then
Maybe this is one of them
Re: Cannot find compatible feature name [message #1842815 is a reply to message #1842807] Fri, 02 July 2021 02:18 Go to previous messageGo to next message
Background: long story short:
I am working on an old project started with xtext 2.10.
Shortly I was switching to XBase->JBase and needed a newer Xtext version for that. So I migrated to 2.25.
Unfortunately, a dependency doesn't work with Xtext 2.25 (see https://stackoverflow.com/questions/67618045/key-formal-verification-with-xtext-2-25).
First, I got rid of that dependency, but I really would like to use this library and therefore migrate back to 2.15 (which at least works with the dep).
I am using an existing ecore model, because I have a textual and graphical editor which use the same model.
Here is my repo https://github.com/Babwenbiber/CorC/tree/develop
Model is in de.tu-bs.cs.isf.cbc.model
Xtext resources in de.tu_bs.cs.isf.cbc.textual.tool
P.S. If You check out the repo you will get some errors in ....tool, you might ignore them, because they come from the graphical editor.
Re: Cannot find compatible feature name [message #1842817 is a reply to message #1842815] Fri, 02 July 2021 02:35 Go to previous messageGo to next message
org.eclipse.core.runtime.CoreException: No property tester contributes a property org.key_project.keyide.ui.isGoal to type class org.eclipse.jface.text.TextSelection
The stackoverflow post shows that you are being totally distracted by a red herring.
The problem is a bad property tester from a third party project. Only mainstream Eclipse plugins are on the stack. Changing Eclipse versions is very unlikely to cure anything, rather it will give you extra incompatibilities to further distract.
You need to debug where org.key_project.keyide.ui.isGoal is referenced, where defined, why now present. Then you can set about remedying the missing definiotion that causes your stack trace.
Ed Willink
Re: Cannot find compatible feature name [message #1842836 is a reply to message #1842817] Fri, 02 July 2021 08:20 Go to previous messageGo to next message
Ok, now I approved, that org.key_project.keyide is never used in my repo.
I upgraded Xtext to 2.25 again and after uninstalling org.key_project.keyide the project works.
However, the KeYIDE is a tool, which I would like to use (not integrate into source code).
When installed I can select some files in my eclipse instance and verify if they are correct (formal verification).
So I tried integrating it manually. I pulled the official KeY repohttps://git.key-project.org/key-public/key/ and installed KeYIDE from local in eclipse.
Somehow, eclipse won't some of the installed classes!?
!MESSAGE Plug-in org.key_project.keyide.ui was unable to load class org.key_project.keyide.ui.starter.KeYIDEProofStarter.
!STACK 0
java.lang.ClassNotFoundException: org.key_project.keyide.ui.starter.KeYIDEProofStarter cannot be found by org.key_project.keyide.ui_1.0.0.qualifier
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:519)
Re: Cannot find compatible feature name [message #1842840 is a reply to message #1842836] Fri, 02 July 2021 08:37 Go to previous message
In the past, this would have been a 'simple' bad class path or missing dependency. Recently the new versions have Java have been moving things around in ways that I really do not understand. I just see much pain. Probably it is a simple problem but maybe KeyIDE is not suitable for the version of Java you use.
Ed Willink
Previous Topic:Issues with Xtext and Epsilon
Next Topic:Highlight keywords with dashes
Current Time: Mon Jun 23 15:57:01 EDT 2025
Powered by FUDForum. Page generated in 0.04328 seconds
