Home » Newcomers » Newcomers » BIRT report designer not getting installed (BIRT report designer not getting installed )
BIRT report designer not getting installed [message #1842777] Thu, 01 July 2021 07:40 Go to next message
vishal gupta is currently offline vishal guptaFriend
I am very new to this tool doing R&D for my organization. Trying to get installed birt report designer, but not able to get installed. Getting error
Location to download the 64 bit install file eclipse-reporting-kepler-SR1-win32-x86_64.zip is here
Installed JDK 64 bit
Installed Eclipse IDE 2021‑06
!SESSION 2021-07-01 09:36:16.522 -----------------------------------------------
eclipse.buildId=4.3.0.M20130911-1000
java.version=16.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN
Framework arguments: -product org.eclipse.epp.package.reporting.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.reporting.product
!ENTRY org.eclipse.osgi 4 0 2021-07-01 09:36:16.771
!MESSAGE error loading hook: org.eclipse.osgi.internal.baseadaptor.BaseHookConfigurator
!STACK 0
java.lang.reflect.InaccessibleObjectException: Unable to make protected void java.net.URLClassLoader.addURL(java.net.URL) accessible: module java.base does not "opens java.net" to unnamed module @96532d6
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:357)
at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:297)
at java.base/java.lang.reflect.Method.checkCanSetAccessible(Method.java:199)
at java.base/java.lang.reflect.Method.setAccessible(Method.java:193)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.findMethod(BaseStorage.java:180)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.findMethod(BaseStorage.java:187)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.findAddURLMethod(BaseStorage.java:171)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.<init>(BaseStorage.java:141)
at org.eclipse.osgi.internal.baseadaptor.BaseHookConfigurator.addHooks(BaseHookConfigurator.java:24)
at org.eclipse.osgi.baseadaptor.HookRegistry.loadConfigurators(HookRegistry.java:178)
at org.eclipse.osgi.baseadaptor.HookRegistry.initialize(HookRegistry.java:100)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.<init>(BaseAdaptor.java:98)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:78)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:480)
at org.eclipse.core.runtime.adaptor.EclipseStarter.createAdaptor(EclipseStarter.java:738)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:259)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:78)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
!ENTRY org.eclipse.osgi 4 0 2021-07-01 09:36:16.812
!MESSAGE Startup error
!STACK 1
java.lang.NullPointerException: Cannot invoke "org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize(org.eclipse.osgi.baseadaptor.BaseAdaptor)" because "this.storage" is null
at org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage(BaseAdaptor.java:123)
at org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:192)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:263)
Re: BIRT report designer not getting installed [message #1842787 is a reply to message #1842777] Thu, 01 July 2021 11:33 Go to previous message
You're trying to run an ancient version of Eclipse on the most recent release of Java. You might get it to work if you add this line to the end of your eclipse.ini:
--add-modules=ALL-SYSTEM
Or you can direct it to use Java 1.8 using a line like this at the beginning of the eclipse.ini:
-vm
C:/path to bin folder of a Java installation/bin
Ed Merks
Previous Topic:Git clone of a specific release
Next Topic:Eclipse starts with blank window on Mac
Current Time: Sat May 28 11:01:43 GMT 2022
Powered by FUDForum. Page generated in 0.03594 seconds
